    Mar 2009
    314
    Squeaky Suspension
    Does anyone else have suspension that squeaks? I can't really tell where it is coming from. My wife's Revo does the same thing.
    Summit, CEN MG10-TR, Losi Micro-T
    Oct 2007
    1,771
    it could be plastic on plastic that is to tight. had similar thing and found that where an arm hinged was to tight and squeaked
    Mar 2009
    GJ, CO
    361
    Mine started to do it last night. I looked around and I couldn't find anything as well. Will take a better look at it later. I will update you as to what I find then.
    Summit
    Feb 2009
    Orillia, Ontario, Canada
    117
    i have the same problem its the plastic arms with the bearings in tem you have to wd-40 it underneath it
    yes it is very fast and NO! you can not drive it!
    Mar 2009
    256
    Yup, mine squeeked and I traced it to those ball joints in the plastic rod ends. Cleaned and lubed and all was good. Last night, I installed some aluminum tie rods and steering links and now I have squeeks again.
    I'll have to lube the ball joints.
    Mar 2009
    Vancouver, BC
    184
    I also got some squeeking from the rockers, simply backed out the screws 1/16 and now I'm good.
    morgue
