Way back in the olden times, buggy tires were 2.0". I think they are now all 2.2" I was wondering, will the Revo fit 2.0" buggy tires (assuming I can find them?)
I did some searching for tire setups for our much anticipated little beasts, and here is what I came up with.
Stock Tires - 3.25 inches in diameter, 1.8 inches wide.
1/10 Truck Holeshots - 3.8 inches in diameter, 2.2 inches wide.
1/10 Buggy Holeshots - 3.2 inches in diameter, 1.8 inches wide (perfect blue groove track tire - what I'll be using).
1/10 Truck Gladiators - 4 inches in diameter, 2 inches wide.
1/10 Truck Bow Ties - 4 inches diameter, 2 inches wide.
1/10 Truck 30 Series Bow Ties - 3.9 inches diameter, 2.2 inches wide.
1/10 Buggy Bow Ties - 3.5 inches in diameter, 1.9 inches wide.
1/10 Buggy Dirt Hawgs - 3.5 inches diameter, 1.8 inches wide.
1/10 Truck Dirt Hawgs - 4 inches diameter, 2 inches wide.
1/10 Truck 30 Series Dirt Hawgs - 4.1 inches diameter, 2 inches wide.
1/10 Truck Badlands (30 series or standard 2.2) - 5 inches in diameter (too big).
I think that going anything over about 3.5 inches in size is just too unreasonably large. I think 3.5 is already large as it is. So we pretty much have to stick to the buggy tires until companies come out with tires specifically sized to the truck.
I will personably be sticking with the stock talons for bashing and the 1/10 Buggy Holeshots for the track. I may pick up a set of 1/10 Buggy Dirt Hawgs if the talons prove to have poor traction, but if their anything like the full size talons, they have acceptable grip for bashing.
And, to specifically answer your question, the wheels will not work. 2.2" is different from 2.0". The buggy tires will be too large to fit on the stock rims.
However, since they all use 12mm hexes, you can just bolt up a true set of 1/10 buggy rims and tires.
BP stands for Brushless Powered - LMT1940/7 CF G2R
Originally Posted by BP-Revo
Just wondering how do you know the stock tires are 3.25" tall?
Thanks
Z....
Here is a photo showing the tires are 3.25" tall that's great i thought they where smaller!!
http://traxxas.com/products/electric...ils/wheels.jpg
Please keep all images to a maximum width of around 600 pixels. To do this, you may need to edit the image using an image editor before you upload the picture to your host.
I have changed the images to links so that people don't have to scroll to read the thread.
Mis'
Thanks
Z....
Would slash tires fit???
Slash 4x4 VXL
Mini Revo VXL
Rustler VXL
Micro-T
i think rear b4 tires will work no? same ones as the one ofna jammin .05 uses?
So, I have been out of the R/C scene for a while (college does that to ya), and back on my really old bandit (like 8 years old), the wheels did not use hexes at all. Is this a new development (less than 8 years), or did/does traxxas just do things differently on the bandit?
This may belong in a different forum.. but hey, you guys seem knowledgeable![]()
Hi most 1/10 scale buggies do not use hexes even associated.Originally Posted by jcm-maxx
Thanks
Z....
Hmm... which ones do? Better yet, what wheels do use 12mm hexes?
I know crawlers use 12mm hex wheels. I'll be trying my spare set on the mini Revo.Originally Posted by jcm-maxx
The Bandit as of the VXL still does not use hexes in the wheels.Originally Posted by SWEETZ28
Stampede
Started life as XL-1 then XL-5 now a VXL
Ofna Jammin uses the same offset to b3 rims the differenceOriginally Posted by tacomarunner500
Proline B3 rims use drive pin
CRT.5 uses 12mm hex
I think that the CRT.5 or Hyper mini ST rims with holeshot M3 will be the choice for racers
yupp those are gona be 1 of my first upgrades, im gona be going to the track a lott!!!Originally Posted by LanceD
REQUIRES: Mounting on a 2.2" wheel Tire Glue DTXR2000, DTXR2002
SPECS: Inner diameter: 2.2" (55mm) Outer diameter: 4.1" (104mm) Width: 2.0" (50mm)
So this above won't work? Searching for some sand type tires....
These below should bolt right on, correct?
http://www3.towerhobbies.com/cgi-bin...?&I=LC4755&P=1
Originally Posted by MuddyTire
do you have a link to these tires? what wheels to use for them guys... im thinking about the new sport of pond skipping! hahah
i found theses
http://www3.towerhobbies.com/cgi-bin...&I=LXDT99&P=ML
what wheels?
acadamy 4wd buggy also used 12mm hexes
then the rear tires off the academy will be the perfect track tires for the 1/16 revo!!!Originally Posted by spcpicard
Kyosho ZX-5 buggy wheels are also hex.
Slash PE, Slash 2wd, E-revo BE soon
I highly recommend the Losi buggy x3000's w/ the ofna dish's they are perfect for racing and will drop right on. (about 3.25)
beware of any of the traxxas 1:10 buggy (bandit) wheels as they are not hex, though maybe take the hex off and it will still work? Have to check w/ traxxas![]()
the hex on a mini is a lot smaller...still the rubber is going to be a lot thicker and heavier than for a mini...if you do with 2 batterys it would proboly go like 40...its not worth it
if its fast its a rustler
These tyres are designed for 1/10 truckOriginally Posted by MuddyTire
Both 1/10 Truck and buggy use 2.2" rims with truck rims being wider and the tyres have a much taller profile, I believe you would be able to use these paddle style wheels on buggy wheels (with a 12mm hex) but the sidewall will extrude from the rim a lot and the rolling diameter of the tyre at 4+ inches would affect the vehicle dramaticly (Gearing and stresses) I am unsure if there are any 2.2 " 1/10 truck rims with a 12mm hex? (Maybe Tamiya)
Myself I would stick with 1/10 buggy wheels as they are a lower profile and will be much closer to stock size.
what 2.2 wheels use 12mm hexes? Link please...
how about these wheels?
http://rc4wdstore.com/product_info.php?products_id=1018
i really like these tires...
http://www3.towerhobbies.com/cgi-bin...&I=LXDU11&P=ML
does the rustler use 12mm hexs?
http://www3.towerhobbies.com/cgi-bin...&I=LXUHV0&P=ML
from what i could find (traxxas based)-
jato
stampede vxl
rustler
rustler vxl
they all use 12mm hexes.
mini revo on order :)
those mini gemini with talons are HAWT.
3sLipo / VXLSlash
PLZ PM Gearing For Gladiatorz
I would stay clear of beadlocks on 1/16 lots of unsprung weight. just my 2 cents.Originally Posted by josh7owens
The hotbodies D4 uses 12mm hexes.. So rear D4 rims are a option
I will be running Jconcepts Goosebump tires, and see if I can get some Rulux rims on it
crt.5 rims are pro bally you best bet size wise the tires are even bow tie type tires too.
Live Fast, Die Early
I think the Truck tires are going to be to big on the mini revo..
The stock tire is only about 3" tall
I think a buggy tire and wheel would be a better size.
http://www3.towerhobbies.com/cgi-bin...?&I=LXDX75&P=7
do these use 12mm hexes?
a)http://www3.towerhobbies.com/cgi-bin...?&I=LXEAK8&P=M
b)http://www3.towerhobbies.com/cgi-bin...?&I=LXTTC6&P=M
I don't think they do have 12mm hexes, to bad those JC wheels would look killer..
I Like these
http://images.amainhobbies.com/image...yotrh001bk.jpg
off a Kyosho DBX
I also like Hyper Mini ST rims in white and black
http://www.ofna.com/images/hyper-min...ni-st-head.jpg
and for the racing look Jammin CRT.5 rims in white or Yellow
http://img139.imageshack.us/img139/6321/pict2894vq5.jpg
All these have a bit more offset than standard buggy, (Kinda like full size revo platinum wheels)
not sure about the Jato as i do not have personal experience with it, but i do have experience with the following vehicles with 12mm hexes.Originally Posted by minirevo
Rustler & VXl
Stampede & VXL
Bandit (rear tires only) & VXL (but you could probably run the fronts with no hex, just the axel pin)
Slash
The rest i am unsure of.
Mods don't let people support Trx
Warning: 92%
wat about some badlands?
http://www3.towerhobbies.com/cgi-bin...?&I=LXTYN9&P=7
The biggest thing i've broken: My wallet.
check this combo axial beadlockswith moabs
the best part is the beadlocks are 12mm hex and the discription for the tire says it gives you an extra 1/2" ground clearence!!!
Drive it, Break it, Fix it, Love it, Repeat
pics dont work
