Results 1 to 9 of 9
    Jan 2008
    McKinney, Tx
    1,967
    single 700 question
    For those of you running Single 700 size motors. I've seen some with all four motor leads connected to the motor and some with only 2.
    Does it matter? Will it be easier on the ESC to have it on all four leads?
    RC Addict #341777
    RC Turnbuckle Jr. ajb1205's Avatar
    Apr 2007
    Alberta, Canada
    3,631
    You do not connect all 4 leads. Plug 2 in and tuck the other two off to the side.
    Vantage/MMM/1515 Revo
    MMM/1518 Revo
    T-Maxx 3.3
    Jan 2008
    McKinney, Tx
    1,967
    ok that's the way it is. is there any benefit to having both hooked up.
    RC Addict #341777
    Feb 2009
    Vancouver, BC
    174
    I've seen it done both ways, personally I went with all four connected on my dewalt 12v conversion.
    e-revo, Dewalt 12v motor, 2 speed conversion, dx3s
    Feb 2009
    4,902
    Inside the ESC, both red wires are connected to the same circuit on the board, as well as both black wires...so you can hook them together if you want, or let one pair dangle, or use one pair and cut off the other pair flush with the ESC or open the ESC and completely remove one set.
    Project: BL Revo Race Quad & BL G-Maxx G3R CF Revo
    Jan 2008
    McKinney, Tx
    1,967
    Cool, thanks for the info! This 700Ho on 4s seems almost as fast as my Novak 6.5!
    RC Addict #341777
    Mar 2009
    314
    I would use both sets plugged in. You will cut the current in half on each so you'll have less of a change of burning something through. Also, if you use both sets and one plug comes out, no worries.
    Summit, CEN MG10-TR, Losi Micro-T
    Feb 2009
    4,902
    That's true, having 2 wires per side will carry more current than one, so using both connected together will be more efficient.
    If you are good at soldering, I suggest opening up the ESC and replacing the wires with good-quality 12awg wire (single positive and negative).
    Jan 2008
    McKinney, Tx
    1,967
    I'm ok at it, so i may give it a try. More likely i'll just hook up both.
    RC Addict #341777
