Results 1 to 25 of 25
    Mar 2009
    41
    what lipos for 1/16 e revo?
    What lipos will fit the 1/16 revo?and what charger will work?will the hyperion 606i work? I think the 1./16 will be a big hit, thank for info ahead of time
    HDC
    Apr 2009
    77
    DuraTrax LiPo 7.4V 5400mAh 20C Car Truck Std Hard Case this is what tower hobbies has as the acessories for it! im getting the 5400 mah lipo if it will actually work!
    Apr 2009
    16
    From what I saw, every battery they list is full size and therefore won't work.
    They need someone to do a sanity check on their accessory list.
    Apr 2009
    77
    thats what i was thinking but i cant find the battery compartment size on the erevo!
    Jun 2008
    333
    battery compartment size on other posts:
    http://monster.traxxas.com/showthrea...ry+compartment
    Apr 2009
    76
    Quote Originally Posted by traxxastmaxx
    The battery compartment is 35.5 mm deep by 101.90mm long and 20.30mm high.
    Apr 2009
    76
    Quote Originally Posted by corracing
    oops didnt see the post above
    Jun 2008
    333
    no biggie..just posted it like 2 secs before..my question thats been boggling me is..3s Lipo..or 12Cell NimH..the 3s is at 11.1v and the NiMh at 14.4v..Which is better for the mini revo??
    Apr 2009
    76
    Quote Originally Posted by suprafanatic26
    you will get higher performans out of nimh but all the batts on the market are only about 1600mah and in series you will get 14.4v with 1600mah
    lipo at 11.1v will still be fast but not as fast, and you can find 3's lipo up to 2200mah and you can run them in perallel at 11.1v with 4400mah
    so its your choice, im going to run nimh...
    Jun 2008
    333
    so would it be better off doing the 11.1 in parallel rather then the nimh in series at 14.4..
    is the top end really that much of a difference with the rpms...
    57,600rpm vs 44,400rpm
    14.4V vs 11.1V
    Apr 2009
    76
    14.4V vs 11.1V
    im not really sure im just staying with nimh cuz its cheep and easy
    Oct 2008
    1,226
    1600mAH ***** 3s lipo's are under 20.00 and in parallel will net you 3200mAH at 11.1v, you will have a higher top end on a 3s lipo than the 12cell nimh that has been proven over and over w/ the velineon system on Rusty's and other vehicles. The lipo holds better voltage under load EXPECIALLY against those small nimh batts, but even against good sub-c's the 3s lipo ruled the top speed and run times!
    Jun 2008
    333
    so in other words..ur saying 3s lipo in parallel is > speed and > runtime..got any links on the *****s that can fit in the 1/16 revo's compartment?
    Feb 2008
    822
    Quote Originally Posted by 8ight-e
    Yep. If you don't like lipo's run 7 cells and you will get good results as well. I will try the Maxamps lipos when I get mine.
    Apr 2009
    76
    http://www.*********.com/*********/s...idProduct=6307
    Jun 2008
    333
    I wanna try out LiPos and see what they are about..cause right now i got EMAXX 3905 running on 7Cell Maxamps and have been nothing but impressed..but maxamps has jacked their prices..so i got my eye on some tenergy lipos on ebay.(cant find any 7cells small enough for the 1/16)
    http://cgi.ebay.com/11-1V-2000mAh-15...1|293:1|294:50
    and the dimensions (if they are right) will fit nice in snug in the battery compartments in the mini revo.
    Quote Originally Posted by Redman65
    Feb 2008
    822
    Be interested to see how well these budget batteries hold up. I will stick with Maxamps though.
    Nov 2008
    New Jersey
    205
    I know traxxas states 14.4 volts, but running 2 x 2s lipo in series will offer 14.8 volts. this issn't that big of a difference in voltage and I can't see that it would causing any damage, but only time will tell. I know I'm gonna try it with some MA's! I'm buying both the parallel and series connectors. I will also buy 2 X 3s and run these in parallel for more run time.
    Sig edited for content.
    Jun 2008
    333
    Quote Originally Posted by Alectric
    I didn't wanna risk that .4 V difference, if they have a limit its there for a reason, these little cars have been under extreme testing for more then a year, and have their numbers for a reason..
    11.V lipo IMO is > then 14.4 NiMh..I don't really see the need to have these at 50mph+, there is going to be no control what so ever.
    So (2)3S Lipo @ 11.1 V in Parallels is the go for 3200MaH, most likely 45min-1hour runtime max..probably 30-45 min avg
    These have been nothing but good reviews so I went ahead and got 4 to test these out in another mini I got..They fit the battery compartment of the mini revo, one of the dimensions is big by like .5MM, nothing a dremel can't fix.
    http://www.*********.com/*********/s...0mAh_3S1P_20C_
    Mar 2009
    41
    Great thread , i agree w/ you 1/16 at 50 would be alittle hard to control
    would my charger http://www.maxamps.com/EOS0606i-AC-DC.htm work with those lipos? whats nice about the 1/16 is the battery are some what cheap compared to the full size version , thanks for your input
    HDC
    Jun 2008
    333
    Quote Originally Posted by hdc
    you should be good..the charger doesn't recommend 4s LiPos but you should be more then fine. plus considering that you paid 150 for that charger! It should charge it no questions asked.!
    Apr 2009
    lexington, ky
    144
    anyone have a link to a 4s LVC? I can't find one anywhere
    Feb 2008
    822
    I will stick with MA 2200 2s. I know my MA 8000HV 2s will lift my 1/10 Slash off the ground so I can't see using 3s and running off road at this scale. Speed run on the street may be a blast. I can't wait to hear what people think of both these kits.
    Apr 2004
    Saskatchewan Canada
    855
    guys there was a thread a little while ago that discussed the 4 cell lipo subject, the traxxas employees said that it will send the esc into over voltage protection and that it won't work so FYI i wouldn't buy a 4 cell lipo for the revo or slash if i was you, you'd just be wasting your money
    Apr 2009
    5
    Quote Originally Posted by josh7owens
    Here's one http://www.*********.com/*********/s...idProduct=4176
