Baysilone Fluid M 500
Product Description* Baysilone Fluid M 500 is a 100% polydimethylsiloxane of viscosity
500 mm²/s. The product differs from organic materials in its physical
and chemical properties such as high and low temperature stability,
good dielectric properties, low interfacial energy, and chemical
inertness. Baysilone Fluid M 500 can be used in a wide range of
applications ranging from heat transfer media and hydraulic fluids to
polish and antifoam formulation.
Key Performance
Properties*
• High and low-temperature stability*
• Low pour point*
• Low temperature and pressure dependence of viscosity*
• Good dielectric characteristics*
• Low interfacial energy*
• High surface activity*
• High compressibility*
• Chemical inertness
Applications*
• Heat transfer media*
• Hydraulic fluids*
• Dielectrics fluids*
• Water repellents*
• Polishes*
• Lubricants*
• Antifoams* *
• Mould release agents
Typical Product Data*
Property Unit Value
Viscosity at 25°C: 500 mm2/s
Density at 25 °C: 0.97 g/cm3
Pour point: ~ -50°C
Flash point: 315°C
Ignition point: > 400°C
Containers:* Baysilone Fluid M 500 is available in 50 kg cans, 200 kg drums, and
950 kg totes.
