+ Reply to Thread
    Dec 2008
    London, England
    212
    Will a Revo 3.3 diff work in a E-revo
    As the title says, will it? reason i ask is because i have FUBAR the ring gear on my diff and there are some revo 3.3 diffs on ebay going cheap
    Dec 2007
    Sylacauga, AL
    1,435
    Yep! They are the same. Next time look at the exploded views.
    15" WB HCR Mutant-Maxx Castle UE FLM 3906
    Dec 2008
    London, England
    212
    I did look at the exploded veiw it just that i remember someone saying there is a diffence between them, if i remember correctly the I-bar
    Dec 2008
    Peoria, IL
    351
    I'm pretty sure you're right about the i-bar not being in the nitro diffs. I think the little u-shaper carriers between the spider gears and case aren't in the nitro version either.
    E-Revo MMM 2200 "The Missile"
    VXL FLM Rustler
    Apr 2007
    Valrico, FL
    1,668
    Are you sure the diff outputs are the same length? I have a center diff for the 3.3 tranny and the distance from one end of the outputs to the other is a good 1/2 inch longer than the outputs on my erevo tranny.
    Aug 2006
    1,728
    The only differences between the nitro and electric Revo diffs are with the diff cups. The diff cups of the ERevo are different to accept the U shaped metal pieces. The I bar can be installed in both 3.3 Revo diff cups and ERevo diff cups. Everything else is the same, the output shafts are the same.
    The exploded views can be a bit misleading as there are a couple discrepancies in them. Look at the different part numbers for the diff cups highlighted in green, they are different. Then look at the part numbers for the gears, they are the same numbers but they are different in the drawings. Also there's a spider gear missing in the ERevo diff drawing.
    It's been fun. See ya.
    Oct 2008
    1,226
    Revo (nitro) diffs will DROP in w/o any modification... with that said the e-revo diff's are designed better and will hold up better to brushless power... so if you have a choice stick w/ e-revo, summit diffs.. or even 3905 emaxx diff's and just change the housing as the insides are exactly the same.
    Apr 2007
    Valrico, FL
    1,668
    doh, my bad, for some reason I thought the question was about the center diff
