Results 1 to 26 of 26
    Mar 2009
    Pensacola,FL
    10
    New setup can't believe it's the same truck
    Bought my slayer in jan and wasn't really impressed of how it handled. A buddy and i went to a local track and ran for about 3 hours and i made just a couple of minor adjustments on the spring collars and it got better. I went and installed a sway bar kit and only have been able to run at work or in my backyard,and i can say that made a world of differance. Today i installed double black springs in the back with 50wt oil and swapped the rear springs up front with 45wt oil in the shocks. Then i installed a slayer center diff kit and the rear brake kit,and also swapped the stock wheels and tires with a sc8. All i can say is i can't wait for the rain to fially be over so i can get this thing back on the track. Just running it a work and in my backyard after these upgrades i can honestly say this thing is one of the best handleing rc vehicles i've ever owned.
    Jan 2009
    Beautiful Downtown North Carolina
    1,449
    yep,all that with the exception of i have switches and dont have the center diff yet,just reset camber and toe per setup sheet,gonna hit the dirt sunday hopefully(gotta let it dry up some) and see the difference,cant wait.........also try the lower holes for upper a-arm pins,makes a difference
    Master of Traxxas engine longevity....
    Feb 2009
    106
    I am going to order the Teckno swaybar kit. Anyone have any reviews on it?
    Dec 2008
    KY
    3,736
    Quote Originally Posted by james#17
    didn't know they had a kit. i don't think anyone here has them.
    shoot a link up so we can take a peek at them.
    chrysler_guy
    Guest
    tekno kit works with a few motors only
    http://www.teknorc.com/product_info....roducts_id=934
    Mar 2009
    Pensacola,FL
    10
    i don't know about the techno kit but i now the traxxas kit is very easy to install and it works great
    chrysler_guy
    Guest
    ive got the traxxas sways. they fit like a glove
    Jan 2009
    1,449
    camber and toe per setup sheet works great!!!!!!!!!!!!!!!!
    Mar 2009
    Pensacola,FL
    10
    Just got back from a hard day of work running my slayer. adjusted my brake bias and wow this thing is like on a rail now. Gonna try to get out to the track tommorow to test this thing out. I'm gonna try to find something to measure the camber to change the setup again.
    Jan 2009
    1,449
    3 threads out on bottom pivot balls in rear,tops all the way in,use tape measure to check toe in,a little less neg camber in fnt,worked great for me, eyeball from front to rear/rear to fnt, and from above to check,if its off its easy to tell....
    Mar 2009
    Pensacola,FL
    10
    thanks man i'll try that tomorrow.
    Mar 2009
    Great Barringon, Ma
    40
    cadman what do you have your caster angle set at? mine truck is still all factory i am in the process of clearing to build my track. I was going to try the lower holes in the front a arms. and about -2 deg camber all the way around. Not sure which way to toe the fronts and rears tho
    Jan 2009
    1,449
    havent checked it with a gauge ,but only thing i did was lower holes in fnt and rear a-arms,3 threads showing on lower pivots,uppers all the way in at the top,little bit less negative camber in front,now i do front end alignments on real cars so i guess i just know but i would imagine mine is just about perfect at 2.5 to 3.0 negative in rear,slighty less in front,slight amount of toe in up front little more in rear,i am going to put arms back up in upper holes like the new setup sheet says but i swear everything guys on here say,plus the setup sheet makes my slayer better and better,thanks everybody!!!!!!!!!!!!
    Mar 2009
    Pensacola,FL
    10
    Went to the track last night. The truck handled great and was pretty well hooked up through the whole course. The only problem i had was that in a tight corner under power the truck wanted to push bad. I would have to let out of the gas almost completely to get it to turn. With that being said on the long straight with a sharp left turn i could just barely tap the brakes to get the tail to brake loose enough to turn. It seems like i read somwhere that the center diff could cause this problem. Does anyone have any advise on this?
    SLAYER with many mods and more to come.
    Jul 2007
    KY
    148
    What weight oils are in the diffs? You may need to go to a lighter weight oil. I have not changed mine, but on my 8T they are waaaayyy thinner!!!! I have been wondering why traxxas put such thick oil in the diffs?
    8ight B2.0,8ight T2.0,XXXSC,Rustler,Micro T and B
    Mar 2009
    Pensacola,FL
    10
    I haven't changed the oils from stock. I was thinking of changing,but i have no idea where to start.
    Mar 2009
    37
    When you turn out the pivot balls I assume you have to also turn out the turn buckles right?
    Also how do I lower the ride height, I can't for the life of me figure it out.
    Jul 2007
    KY
    148
    On you 8T 7000, 10000, 5000 that is front to rear. The thinner oil should loosen up the diffs, and not make it feel like it has a spool in it.
    Bombss to lower your ride height, you need to loosen the spring tention, the adjusters on the shocks.
    Mar 2009
    rossville, GA
    252
    I put some gas line under my shock pistons to lower mine.
    Slayer modded 3.3
    losi 8ight t mach 427
    Mar 2009
    37
    sicsam, can you post a pic of that?
    Jan 2009
    1,449
    hey bombs the new springs are different lengths,shorter,this lowers your height too
    Mar 2009
    37
    I got a whole set or the Teflon coated GTR shocks sitting on my workbench waiting to be installed. Which springs should I get? Does Traxxas make them or are they from somebody else? I keep hearing about the double black and double purples, where do I get them?
    Jul 2007
    KY
    148
    You can get them through traxxas.... buytraxxas.com.... lookup the slayer, and under suspention and they have many different springs. I think that they are like $6 a pair.
    Apr 2009
    sask canada
    69
    is there any set up sheets available on the site or do any of you guys have one you can send me thanks
    Jan 2009
    266
    Quote Originally Posted by jdw652
    http://www.traxxas.com/support/kb_se...l&cat=0&id=619
    Apr 2009
    sask canada
    69
    thanks thats perfect
