Results 1 to 13 of 13
    Jan 2009
    kingston ny
    301
    im fed up....ahhhhhhhh
    ok sooo i bought some new rims and tires for the making of my backslash....
    and i hate glueing tires....
    so i ruined one of my panthers tring to glue it on......
    anyone have any tips for the others....
    cause its bad enough i have to buy another set of $25 tires to replace the messed up one......i really hate glueing tires.......
    Oct 2008
    Soldotna, Alaska
    730
    im with ya there, i hate glueing tires-and within a few days i should have 8 to do.
    Jan 2007
    Crystal, MN
    1,869
    Put the tire in the bead, then pull it back out and place a small dab of glue on the tires lip. Put the tire back into the bead and massage it and allow the glue to move along the bead. Do this 8-10 times around the tire, using as little excess glue as possible.
    BMW E21 323i.. My baby.
    Jan 2009
    115
    how did you ruin a tire, gluing it on a wheel?
    Jan 2009
    kingston ny
    301
    well i tried to glue the tire on one side,and it ended up gluing half off the bead..(meaning half of the lip of the tire was not all the way down on the rim.. and couldnt fix it to i took it off....and it tore up the lip of the tire...
    Jan 2009
    229
    is there a way to unglue tires? I want to unglue them tape the inside for ballooning and re glue them. sorry for the threadbust and the noob question.
    Jan 2009
    kingston ny
    301
    Quote Originally Posted by forced00si
    put them in a pot of boiling water,,it will losen up the glue and rubber...
    be careful when squeezing out the hot water......its hot as wooooo
    Sep 2008
    Wisconsin
    276
    do a youtube search
    you can bake or boil
    i bake because it has worked for me in the past
    Slash/Max/Lehner4200/3s/10000mah
    Jun 2008
    397
    get bead locks! they are worth every penny!i use these
    http://www.amainhobbies.com/product_...ducts_id/22053
    Long live Duck Tape!
    Jan 2009
    115
    to remove CA glue, buy Debonder from your local hobby shop. and presto, it debonds the CA glue..
    Jan 2009
    Wisconsin...for now.
    455
    Is taping the tires really worth it? The weight added to the wheels affects the truck twice as much, compared to just adding weight to the chassis, because the motor has to work harder to spin the wheels. I know that I would never consider taping the wheels, I have 20 mL of water in one of my wheels and it affects the performance quite a lot.
    United States Air Force
    At AFBMT..
    Jan 2007
    Riptide Raceway Winnabow, NC
    1,864
    I do the boiling method. Works well. I have tires that have been on 3 different wheels.
    As for gluing the tires, like Rocky said, put the tire in the bead, pull it back slightly and add glue. You don't need a ton of glue. For softer compound tires, I have found that putting them on the wheels a day or so before you glue them makes a big difference. It allows the tire to conform to the wheel.
    TR17
    To err is human, to arr is pirate!
    Jan 2009
    115
    and, for me, I use Shoe goo to mount all my tires, It works great, its removable, and is holding up to my VXL on 11.1 just fine... I suggest it for everyone,.....just make sure you let the shoe goo dry over night...
