Thread: shock fluid
    Mar 2009
    rossville, GA
    252
    shock fluid
    Just put in thicker shock fluid(55 wt.) and can notice a big differice with the stock springs on even though i have some 1.8 and 2.0 coming along with a close raio gear set for trans. Is anyone else running a close ratio trans?
    Slayer modded 3.3
    losi 8ight t mach 427
    Dec 2008
    Gettin' Lucky In KY
    3,882
    i've been wanting to try some 45 or 55. i've got 45 and i can't remember if i have 50 or 55. if it's raining tomorrow i might do some tinkering.
    Jan 2008
    Brunswick, Georgia
    408
    Quote Originally Posted by CarGuy7a
    I run 55 weight in my rear shocks and 50 in the front along with stock springs and a sway bar kit. This thing is solid now. I have to be driving stupid to get it to flip in the dirt now. The road is a different story....... This thing does not like asphalt... But of course, its not made for asphalt...
    Support your local hobby shop!
    Mar 2009
    diamond bar, ca
    112
    Quote Originally Posted by sicsam
    same here. i have the 1.8 & 2.0 spring rates .ive recently experimenting with 50 wt oil on both front and rear. i use to run 45wt. i think 45 is runs good. but 50 really takes the bigger jumps better.
    i also have the short ratio 2 gears. right now im on 15 bell and 38 spur. it works realy good on my local track( which is designed for slash/slayer ). really peppy. i could get the bigger jumps with less distance to pick up speed. with the close ratio gears, i notice that the 2nd gear is alot more punchy. like a massive amount of torq when it shifts to 2nd.
    Mar 2009
    rossville, GA
    252
    Thats what im wanting is to stay in a good rpm range, thats why im going to the close ratio gear set because my local track is set up for 1/8 cars so i need all the help i can get. I also have 1.8/2.0 springs coming but still havnt got the sway bar kit yet.
    Slayer modded 3.3
    Mar 2009
    diamond bar, ca
    112
    the sways help. i set the front all the way stiff and it actually make the truck lower. you wont flip as much.
    if your track has mostly big jumps which are usually designed for 1/8 truggy/buggy. then go thicker oil and harder spring rate. i catch soo much air that i beat my slayer up. i hate the sound when it bottoms out on landing. well not that you could avoid bottoming out. all r/c trucks bottoms out. id go mabe next rate up. 2.0 2.2 with 50-55 oil or mabe even 60. just a suggestion. i havent actually tried it. but my 1.8 and 2.0 spring with 45wt was too soft on my local truggy/buggy track. if u wana see the track go to revrace.com
    next i need to get a center diff and rear breaks.i heard/read you jump alot better and shoots to the turn alot better.
    Mar 2009
    rossville, GA
    252
    I heard mine hiiting bottom sunday thats why i ordered every thing monday. And you can see my track at battlefeildraceway.com
    Slayer modded 3.3
