    622
    ***** ********* problems
    well i have 2 of the ***** ********* 2s 4000 25c lipos and one of them is now saying connection break when i trry to charge it and when i plug it into the truck there is nothing.... what should i do... should i say o it was $28 and probably 20 charges through it and get a new one...or should i try to contact ********* about it
    thanks
    bigdog
    BRUSLESS RULES
    Apr 2008
    Wisconsin Around Appleton
    1,314
    it is not worth the money to ship them back to hong kong so i would crack them open and re solder them
    even if you break them you got your moneys worth
    if you can control it, it is too slow
    RC Turnbuckle Jr. streetdemon's Avatar
    Jun 2003
    The home of the brave....
    3,119
    From what I understand they are not that hard to fix as long as you are somewhat handy with a soldering iron, it is also a fairly common problem. All you really need is the iron and some new shrink wrap for it. How do you like it by the way? I was looking into getting some.
    Some like R/C's that are fast, others like nitro
    Nov 2008
    Somewhere between Nitropia and Electropia.
    360
    I've tried one of ***** lipo product called RHINO...no problem or whatsoever...just open the wrap and find out what's wrong...good luck
    622
    well it worked great
    ok...how do i open thr case up because it is a hard case
    BRUSLESS RULES
    622
    is there a special way to open a hard case
    BRUSLESS RULES
