Results 1 to 15 of 15
    Feb 2009
    Vancouver! B.C., Canada
    91
    Transmission Noise
    Is it normal for my Revo to be quite loud after I change out the 19t pinion for a 17t? It also feels like it's dragging as soon you let off the throttle.
    Oct 2008
    York, PA
    107
    sounds like your gear mesh is too tight.
    E-Revo: MMM Combo, SPC 2S 8000mah Lipo's
    Jan 2009
    Romania
    20
    Or you can try to put some light oil. Mine is quiet now after the lubrication.
    E-REVO:8 LEDs,2 speed,Novak HV 5.5,Road Rage tires
    Dec 2008
    canada, alberta, sherwood park
    289
    no cwczx3 it right the only reason for that is the gear mosh is too tight there is no reason to oil nylon gears. the only other option is did you buy the right tooth size gear?
    -Rustler VXL widefront
    -E-REVO
    -RC18
    Feb 2009
    4,902
    Yes, never oil nylon gears...they don't need it for the main thing, and the oil will attract dirt and grime and destroy the nylon gear very quickly.
    Project: BL Revo Race Quad & BL G-Maxx G3R CF Revo
    Feb 2009
    91
    when i go slow it makes a terrible sound but then when i speed up it sounds normal i looked at the geer mesh and it was fine.
    Dec 2008
    289
    did you check out the rest of your drive train... i really dont know
    -E-REVO
    -RC18
    Sep 2008
    255
    did you do the paper test for the gear mesh?
    Feb 2009
    91
    Quote Originally Posted by rabbithazen
    no but i know it's not it
    I put the 19t back in and it sounded fine
    I gues ill just have to leave the 19t in
    Feb 2009
    91
    Quote Originally Posted by magicman1312
    I did the paper trick but it didn't work
    Feb 2009
    91
    I dont know the guy at the shop said it was for an emaxx so i figured it would fit.
    Dec 2008
    289
    no i think i know the problem... its because the pinion was too small so i wouldent mesh right. when the mesh is set you should be able to mover the pinion and spur seperate from each other just a little bit.
    -E-REVO
    -RC18
    Feb 2009
    4,902
    Check the offending pinion for damage to the teeth, or debris in the teeth.
    Feb 2009
    717
    If they are the shiny traxxas pinions you need to file the teeth. I had the same problem and after looking at them really closely with a magnifing glass I noticed that there is a small ridge on one side of the teeth. It is really small but if you look close you can see it. I used a nail file and gave eash tooth a little TLC and it works fine without a problem or noise once the ridge is gone.
    If it didn't break you can do it again.
    Feb 2009
    91
    yup there the shiny ones allright. thanx alot I'll get to fileing them soon.
    "A penny saved, Is a penny earned"
