Which rims are you guys using to put regular stadium truck rims on the Slash? Rustler front rims or the rears since they have different offsets? Also rear or front if you are using HPI rims? Thanks.
Traxxas Slash w/ Mamba Max/CM36-s7700Kv/7cell Nimh
rustler rears all around
Thanks. If rears are put all around will the front and rear track width be the same?
almost perfect. really really close
im using traxxas pro star rims for the rear throughout and gladiators, pro traxx for tires
Velineon Slash..With a Wing :D
currently broken
Has anyone used fronts all around for a wider stance?
alot of people use the rpm revolvers (narrow). these widen the stance a bit since the offset is only .69 inches.
...true story.
