    Dec 2008
    Tulsa metro area
    331
    Can Anyone Tell Me How To Measure The Pitch of a Gear?
    I need help on measuring the pitch of a gear I want to have duplicated.
    Curt
    Miami, Florida
    3,859
    Quote Originally Posted by crrccarz
    Curt
    I guess if you have a very precise caliper you can do the math and figure it out.
    OK – So what is Gear Pitch? Put simply, it is the size of the tooth on the gear. The standard accepted method for working this out is known as the pitch diameter and this, simply means by the number of teeth of a consistent form that may be accommodated on a ONE inch gear.
    Therefore a 64 pitch gear would have 64 teeth if the gear were 1” in diameter. Similarly an 80 pitch gear would have 80 teeth if that gear were 1” in diameter. It’s that simple. So basically, the higher the pitch number, the smaller / finer the form or shape of the gear tooth becomes.
    http://www.abslotsport.com/page8.html
    I have no idea if this is correct or not, don't quote me on it.
    Mar 2007
    near New Orleans
    5,903
    This place has just about every gear you need and will even custom manufacture to your specs.
    http://www.sdp-si.com/
    E-Maxx Neu1515 1y/MGM 5s
    Dec 2008
    Tulsa metro area
    331
    Great thanks guys!!
