+ Reply to Thread
    Hampton GA
    1,690
    shift point problems
    i recently upgraded my pro.15 car to a 3.3, the tranny started to shift early. increase in power cause it? now i put a os.18tz in it and it semms to go into second as soon as i pull the trigger. do i need to tighten up the set screw in the shift hub, or do i have to replace it?
    auto 5, great guy to deal with
    San DieGO CA.
    358
    tighten the shift point screw.. and mabey it shiftes earlyer cus these engines are more powerfull
    keep jabin
    Apr 2007
    2,502
    You hold the spur gear with the hole in the metal part is up. Roll the car forward while holding the spur until you see the little screw in the shifting hub. Then take the 2.0mm driver (second biggest) and tighten it little by little until you get the shift point how you like it. If that doesn't work you might need to replace the shift hub thing.
    Good luck!
    Dec 2008
    Worcester, MA
    184
    I'm not sure this is a problem as I haven't ran the car out on the road yet, but when I pick up my Tec and rev the engine, once it shifts gears into 2nd the wheels lose power and the motor revs real high. What gear or driveline part is likely the culprit?
    Hampton GA
    1,690
    i know how to adjust the shift point, just wanted to know if that was my problem before i mess with the shift point. i messed with the shift on my maxx and screwed it all up.
    Jun 2007
    140
    your shift hub is slipping on the shaft. you either need to tighten the set screw that holds it to the shaft or replace the hub
    Apr 2007
    2,502
    What be said, do that first and then if that doesn't help then adjust the shift point, yes... Good luck!
