    Jan 2008
    USA
    1,514
    Bladder Part Number
    I went to clean some shocks yesterday as it's been quite a while and found that all 4 bladders were bad. They are stock shocks but have the big bore caps on them. I guess when I put them on and tightened them all the way, it cut off part of the bladder and in two of them, the bladder was actually inside the shock body instead of on top. Anyway, I need new ones and looked on the blow ups for the VXL and couldn't find what they were. Anyone know?
    Also, when I go to rebuild the shocks, should the shock caps only screw down most of the way but not all the way down?
    I guess another question is should I rebuild the whole shock? The shafts are bent on the rear shocks so I will need to replace those. I have spare e-clips and such so I might as well rebuild them but what else do I need to do that? O-rings?
    Any advice would be great. Thanks!
    EDIT: I saw the shock rebuild kit is only $2.39 on Tower and has the bladders and o-rings. Which brings up another question. Does this rebuild kit only do one shock or does it do two? Two would be excellent. I'll have to see if my LHS has them in stock.
    May 2007
    719
    Quote Originally Posted by healthyfatboy
    Each rebuild kit will do two shocks.
    Jan 2008
    USA
    1,514
    Thanks a lot!
    Mar 2003
    Wherever the road takes me.
    36,942
    The part number for the diaphragms is 1765.
    There will be a small gap at the bottom of the cap when you put them on.
    Yes, rebuild them. You already have to take them most of the way apart anyway... you might as well go the extra distance and replace the o-rings as well.
    Jan 2008
    USA
    1,514
    Quote Originally Posted by cooleocool
    When you say a small gap, is that with it tightened down all the way or that I should leave a small gap (~1mm) when I tighten it down?
    Mar 2003
    36,942
    I normally just tighten mine down, but I have heard other members here talking about how they have to stop to get the gap at the bottom. I'm not sure what accounts for the difference... just be sure to leave a 1 mm gap at the bottom.
    Jun 2007
    886
    I had the same issue a while back with the bladders tearing from tightening all the way down. Now I add some of plumbers teflon tape around the threads and tighten them like cooleocool said, down to about 1 mm or a fingernail width.
    Rustler VXL FLM-Pede VXL Slash PE
