I JUST got in from a day of bashing and the v3 worked flawless. truck is sick. i cant keep the front end down on 4s. i cant imagine what its gonna do on 6s. GREAT JOB CASTLE THANKS.
Lets hope they have it right this time. Their Quality Control department has really let alot of people down in the past with this MONSTER screw up.
Originally Posted by slvrbowtie
You'll be able to do standing forward and backward flips![]()
. It gets old though.
Brushless Emaxx
Brushless Kyosho ST RR
Supermaxx
trying not to wheelie but have not figured it out yet
punch control in the mmm settings....turn it up a bit....a good setting for me was around 70%
But I have the extended rear arms, so you may need a bit more.
Get a wheelie bar and put the wheels so they are touching the ground haha.
What am I supposed to write in 50 characters?
Incorrect.Originally Posted by detox
It has nothing to do with quality control, it has everything to do with being a new product with some design issues that needed addressing.
Dont consult me, just read the FAQ.
I like the fact that its brushless but what i dont like is how low the ground clearance is. i was also wondering if the suspension is ajustable because if thats all the ground clearance it has, then its not a true truck.
Are you serious?Originally Posted by Chris York
The (E)Revo platform is about as ajustable as it gets. Ground clearance is set the way it is from the factory with the thought of it being a "race" monster truck. Check this thread out for one that has been adjusted to the max and you'll see what I am talking about.
http://monster.traxxas.com/showthread.php?t=440458
Eat my road grit, liver lips! -Clark W. Griswold
4s huh? I was planning on going 6s because of all the hype, but I may have to change my plans. If two quality 2s packs will make it wheely on demand, that's all the power I'll need. I WANT the nose to stay down.... Looks like I'll need a wheely bar then... LOL
2 Slash 4x4's, B/L Rusty, and a Crawler
My plans are to upgrade the stock e-revo with a MMM v3 with the 2200 motor offered from Castle Creations for my son's Christmas gift.
A few folks on this forum tried a 5s (3S and 2S in series with the same mAH). Sounds safe from pushing the 6s limit and may try against some bad reasons for trying a 5s.
Also for those few videos posted, it seems like there is a lot less control with respect to wheelies (probably because the less weight of the missing forward titan motor and extra weight of the rear brushless motor)/
Hoove mentioned controlling the punch to 70% or greater.
Any others made adjustments for better truck control?
4S is plenty on this truck for sure, but.. most of this hobby is geared for the faster setup.. so I say get a couple 3s packs and go for it!
Stegra.. did you turn the timing down to lowest? that'll take some grunt out of it.
Reformed nitro operations specialist..
why run 5s? its not as efficient! run 6s and gear it down! your setup will run cooler pull less amps and you will have a biggeron your face
Not neccesserly. Without knowing the specific efficiency band (in rpms and volts) of all the motors that are suitable, there is no way of knowing if the MMM motor is better on 4,5 or 6s lipo.
That said, I would prefer to run 6s and gear down more, as it allows you to gear up for when you want more insane speed. 5s however would be a nice mix of good temps and nutty speed without messing with the gearing too much- fewer pinions and spurs to buy![]()
yeah thats true, if your not in to messing with the gearing alot.Originally Posted by The Oracle
they should make a 5 speed autostick for the erevo! lol!
I have CC response from this exact ? Of how many cells.It was the general consensus that 4s will probably be the best.The efficiency should not really be an issue on 4 or 6. Here's the thread. http://www.rc-monster.com/forum/showthread.php?t=16068 For me with this kv of motor I'll save the 6s for speed runs only.
_
_
_ 3 lines are all that's allowed in a sig.
well im going to stick with my 4s ma 6000's for a wile![]()
they dont even get warm with my mmm and 1y and the power is![]()
im good for a wile
Rock on Brushlessman!
support the military: Mccain / Palin
lay low! i dont want to make i liberal mod mad!Originally Posted by fmj40
wow i wish i had money to do all this but i dont. ill hav to stick with a sidewinder in my rustler for awhile.
srry i like obama/biden
time for college.
