    Aug 2008
    76
    ESC MMMv2 Issue ?
    Having i problem with the forward throttle. As soon as i push the throttle (1%) my Neu motor goes like say as it would do on 20% throttle. ON reverse i can nicely start with 1% it will go 1% speed but not on forward. Any ideas ?
    what am i doing wrong. Tryied all setting on the ESC but no changes.
    using 2.4Ghz 3Pm Spectrum. did calibrate. Still no luck...
    May 2007
    Kerrville Tx
    4,997
    send it to castle! and get the v3
    Aug 2008
    76
    thats whats wrong with it ? hmm i just bought the ESC 3 weeks ago. I guess i got the last V2 how can you tell they have V3 out. IF its a problem they better have it under warranty and replace it for me for Free i hope
    Jan 2007
    Hollywierd, FL
    2,779
    Try swapping any 2 wires going to the motor. Sending it in for a v3 is an option, but you have a 1 year warranty on it and can do that anytime in that year.
    Run it, break it, fix it, love it :]=~
    Sep 2008
    91
    im not sure if this will solve your problems however, if you want to wait a few more days castle stated they would be releasing a new software update for MMM on there website under the download section (something after ver 3.11)... hope it works for you when they release it.
    Sep 2008
    606
    Sounds like you have it calibrated or programmed wrong- start from scratch ensuring you have everything set correctly on the radio (nothing reversed on the throttle channel).
    Set the esc via castle link to:
    70% punch control
    30-40& reverse
    forwards-brake with reverse lockout
    timing to lowest or low
    drag the throttle curve down a little bit near the start- that will add a bit of exponential and improve the low speed controllability.
    look at the dead band setting and perhaps decrease it (or increase it).
    Read the manual carefully- lots of info to be gleaned.
    Dont consult me, just read the FAQ.
