Results 1 to 39 of 39
    Ontario
    335
    Getting brushless e-revo
    Getting sweet deal on brushless vxl e-revo with the mamba and castle creations
    Was wondering if there's anything I should look out for before buying
    New the electric but not new to the hobby I own a tmaxx nitro
    kansas
    7,862
    If it is a vxl you need to go here
    http://traxxas.com/forums/forumdispl...-Slash-VXL-4WD
    Ontario
    335
    It's 1-10 tho not 1-16
    Aug 2013
    921
    Quote Originally Posted by traxxaspro View Post
    there is not a 1/10 vxl that's the confusion, test drive it and make sure it runs smooth without grinding noises.
    1,575
    Check the Diffs, Drivetrain and Trannsmission. Remove the Motor and see if everything runs smooth.
    If you turn one tire, the other tires should rotate in the other direction.
    Check for excessive play on all moving parts, drivetrain, suspension...
    Check for ripped tires or wobbling. Jack up the vehicle and give it some throttle...
    Check bearings for play and squeeking noise
    Check Electronics -> Make test run and see if everthing works properly, esc, motor, servo, transmitter, receiver, check temps on Motor and ESC after the run
    Check for pinched or broken Cables
    Ontario
    335
    Turns out truck is great
    Just missing the wing and wheelie mount
    Anyone got any links for them
    1,575
    Nice dude check out the exploded views.
    http://traxxas.com/explodedviews/E-R...-Rear-Assembly
    Ontario
    335
    Thxs much appreciated
    Montreal, Canada
    1,838
    so what ESC you got in it finaly since it is a 1/10
    Live life to the fullest
    Ontario
    335
    It's the mamba creations
    Already bent the rear toe bar are the true tracks worth it ?
    Only running on 2s very touchy throttle
    Also the brake is there any way to trim it down
    It flips foward very easily
    1,575
    You need the castle link to programm the mamba monster esc
    How did you bent the rod? Did you hit something?
    Ontario
    335
    Probably a end over ender bent it
    What's this castle link you speak of
    Ontario
    335
    So With that u can program the brakes and stuff
    Is this the same thing
    http://www3.towerhobbies.com/cgi-bin...&I=LXGVR8&P=ML
    1,575
    Yes this is it.
    You can do all kind of programming:
    https://www.youtube.com/watch?v=N6pUV7Gz21s
    Montreal, Canada
    1,838
    Yeah its a different ball game running a 4x4, you have to be careful on braking. To brake I just ease off on the throttle and some times do not use brakes at all.
    Ontario
    335
    Awesome looks like I need a few things from tower hobbies
    Placed an order new wing n mount n wheelie bar with the castle link
    kansas
    7,862
    after watching some of the vid. I would set the LVC to 3.4v per cell and set the brake to 30%, and a few other things..
    Ontario
    335
    Alright thanks
    Been reading a lot about chargers and battery's seems like spc way to go
    But what about a charger
    Sorry kinda a noob to electric
    Sep 2010
    middle o nowhere Ill-inois
    784
    SPC is awesome. I have the Traxxas ez peak 6 amp charger got it used with one of my e Revos. It works great and very user friendly. Dual adapters if you want them have to be bought separately. But I'm sure others may chime in with less expensive options.
    Summit, ERBE X2, 4pdes, 2pdes, etc lol
    Ontario
    335
    The one I got now just standard prophets 2c or 3c charger
    Bloomington, Minnesota
    392
    Whatever charger you have, make sure it has the ability to balance as well. THis will get you the best performance and longest life out of your lipos. SPC are great, and so is Traxxas' offerings. You can get a 6a charger and 2 2s batteries and you'll be set. Id step it up to 6s after you are used to those, and be prepared to break more stuff.
    _____________________
    ERBE/RUSTY VXL/ALIAS
    Ontario
    335
    Was thinking going to 3s
    As for the charger being a balance charge I doubt that it's only goes to 2a
    Oct 2004
    Winter Haven, FL
    168
    I use SMC lipos. SPC is good also. I bought a charger/power supply combo from ProgressiveRC.
    You can see it here in my build thread and everything else.
    http://traxxas.com/forums/showthread...ss-Build/page3
    Ontario
    335
    Yeah I saw that but that's a little out of my budget I think
    Jul 2014
    148
    The onyx is a great charger with a lot of options. They make a single battery and dual battery charger.
    E - Revo Fixing it daily.
    Apr 2014
    125
    Quote Originally Posted by Revo2Fix View Post
    I have an Onyx 245 on the way for my Lipos, but learned after I ordered that it does not offer storage mode or discharging. Should I just set the LVC to 3.5 and run the batteries in my EVBE until the LVC kicks in, then leave them until next time I am ready to charge?
    Ontario
    335
    No idea probably
    Jul 2014
    148
    I just always charge after I use them. I try not to worry too much. Batteries do have a life span and get weaker over time. I guess if I had a 200$ battery I would think differently. But I don't spend more then 50 though.
    15,683
    Quote Originally Posted by Mindprey View Post
    I set my ERBE's LVC and my LVA's at 3.5 volts per cell and my SPC batteries are always at 3.8 to 3.9 volts per cell when I bring them into the house.
    I ran six packs between my Summit and ERBE a couple weeks ago. I put them on my Powerlab6 to put them at storage level and all were done after 140 seconds.
    It doesn't matter how you get to storage...just get there.
    Alt-248 on the number pad =
    Apr 2014
    125
    Thanks. That's what I thought, and glad to hear I was close to right. This will be my first ERBE and first venture into Electric/Lipo. Figure I can upgrade my charger if I get as involved as I think I will with the ERBE, lol. I already have a shopping list a mile long.
    Jul 2014
    148
    I'm just wondering if all that effort is worth it unless your spending big bucks on batterys. My first lipo is still kicking from like 3 years ago. And all I do is charge when done. And especially before a storage time.
    Ontario
    335
    So revo u store ur battery's full ?
    Jul 2014
    148
    Yea I thought you were supposed to, but it sounds like it's not the optimal choice.
    15,683
    No, it is not optimal for LiPos (many of us found out the hard way) although it is correct for NiMH packs.
    Although your packs may still be "kicking" they'd be kick harder if treated as recommended above, no matter what their cost.
    Aug 2013
    Brazoria, Texas
    1,079
    I use a hitec x1ac. It only charges one at a time but it has features to charge lipo's, life's, nimh's, and nicd's. It goes up to 6 amps and has balancing, discharging and brings lipo to storage. Its practically the same as the traxxas lipo balancer, just a little cheaper.
    I always heard it was best to put the battery at lipo storage once done. I couldn't do this for the first couple of weeks cause I had a cheapo balancer. I was in fear every night that they might swell or burst.
    Revo 2.5 upgraded to 3.3.
    Jul 2014
    148
    So don't charge them after I use them? I did recently purchase more of the same battery and can't tell a difference between the two. I don't think my onyx have a storage feature. So I don't know if it would really be worth buying a whole other charger when my batteries cost 45$
    Jun 2014
    6
    Depends on how long they will be sitting. If a few days to a couple of weeks, it is probably fine to leave them at the state you findings running on. (You do stop running before they get all the way down to the low voltage cut-off, right?
    Longer than that charge them to a storage level. If your charger has such a thing great. If not try to hit somewhere between 50 to 75 percent of a normal full charge.
    The two levels that degrade lipos are too low and very high. Leaving a lipo at a full charge for a long time will make it difficult and eventually impossible to get it to charge back to that level. Worse, whatever your new full level is will be susceptible to the same issue so after many cycles of charging it all the way and leaving it like that will eventually cut the top 10 to 20 percent off your voltage.
    As for leaving it too low, as you might have heard, if a lipo "bottoms out" with too low of a voltage, whether by running or by extended storage, it will magically turn into an expensive doorstop.
    Jul 2014
    148
    Yea the lowest I've put them on and read is 3.6 . I have mine set to cut off at 3.5. But thanks for that info!! I now know how to store them!
