Page 1 of 2 12 LastLast
Results 1 to 40 of 43
    Dec 2007
    Broomall, PA
    2,139
    Making my E-Revo Brushless?
    I am planning on getting a MMM v3 and Castle 2200KV Motor/ESC Combo. What else do I need to get it running?
    Pinions, Connectors? I don't know. What do I need? haha
    E-Revo - Single 700-HO - SPC 2s 8K LiPo
    Dec 2007
    Broomall, PA
    2,139
    Also, What gearing? And will it fit in the stock mount?
    Oct 2008
    In the shadows...
    204
    Read the FAQ.
    You will require:
    5mm bore 32pitch pinions
    It will fit the stock mount just fine
    You will need to make or by a series adaptor to run a pair of lipos- connectors is up to you, but TRX are fine.
    A digital radio is higly recommended.
    Once you have it, set the puch control via castlelink to about 70%, brakes to 40-50%, reverse to 30%, timing to low or lowest, and throttle mode to forwards-break-reverse with lockout.
    As for gearing, you didnt specify your voltage:
    4s:
    68/24 = 37mph
    62/24 = 40mph
    58/24 = 43mph* jato3.3 spurgear
    6s:
    68/20 = 45mph
    65/20 = 47mph
    62/20 = 49mph
    68/24 = 53mph
    65/24 = 56mph
    62/24 = 58mph
    Anything else will cost you $10 to answer....
    I am SuicideNeil, please dont shoot.
    Dec 2007
    Broomall, PA
    2,139
    THANKS! I am running TWO 6 Cell's and TWO 7 cells.
    Also, 32P on a CC 2200KV Motor?
    May 2007
    Kerrville Tx
    4,997
    Quote Originally Posted by DiFabio42
    yes. 5mm though
    Dec 2007
    Broomall, PA
    2,139
    Quote Originally Posted by brushlessman
    yes. 5mm though
    5mm is Mod 1 not 32P. Am I buying a 32P 20T Pinion or a 5mm (Mod 1) 20T Pinion?
    Oct 2008
    In the shadows...
    204
    WRONG.
    5mm is the size of the hole in the middle of the pinion, not the pitch of the teeth. You are buying a 32pitch (mod 0.8) 5mm bore pinion.
    Dec 2007
    Broomall, PA
    2,139
    Oct 2008
    In the shadows...
    204
    Yep. Just choose the number of teeth you require- 12/ 14 nimhs are not good batts to feed the MMM combo though, they will be eaten alive if you gear for higher than about 35mph, trust me. So 68/22 is about the best you can manage really, maybe 22/65 if you are lucky.
    Dec 2007
    Broomall, PA
    2,139
    Quote Originally Posted by thedude
    Is 68T Stock Spur?
    If so I'll go 21/68.
    Oct 2008
    In the shadows...
    204
    68T is stock yep. You may have difficulty with some places selling odd numbered pinions (tooth count wise), but RR ones should be perfectly fine if they have a 5mm bore mod 0.8/ 32pitch 21toother. Save up and get some lipos though, cant stress it enough for BL vehicles.
    Dec 2007
    Broomall, PA
    2,139
    I know, I know. Christmas is comming and so is Lipos/Charger
    Any thing else I need other than, Soldering Iron, Solder, Connectors, Wire for making my Series Connector, Flux, Wire Stripper, Pinion, Dremel,
    Is 14 Gauge wire good?
    Oct 2008
    In the shadows...
    204
    14g wire isnt ideal- better off with 12g. You shouldnt have any other issues, it really is just a case of soldering on some plugs and wires, programming the esc, and away you go.
    You'll probably need new diffs sooner or later, but thats another story....
    Dec 2007
    Broomall, PA
    2,139
    I did soldering in school so I can do it kinda good. Just need help with a Pos/Neg and stuff.
    Dec 2007
    Broomall, PA
    2,139
    Anymore tips/info for the ESC/Motor hook up?
    Oct 2008
    In the shadows...
    204
    Plug the wires from the motor into the esc... er, thats it.
    As for how to wire up your batts:
    http://www.scriptasylum.com/rc_speed/_wiring.html
    select the '2 series battery packs' option. Simple as pie....
    Dec 2007
    Broomall, PA
    2,139
    I found this tutorial that shows how to solder the leads on a Traxxas connector. I'll look at that before I solder it.
    Jul 2004
    Orangeville, Ontario, Canada (North of Toronto)
    79
    You will require:
    6s:
    68/20 = 45mph
    65/20 = 47mph
    62/20 = 49mph
    Thank-you that's beautiful information! I've read the FAQ ( a few times ) but that list is so much more simple.
    Sep 2008
    Schuyler, NEBRASKA
    556
    :O bbq, i used to know a guy with that nickname... lol random but your name caught my attention.
    E-revo for sale. PM me for more info.
    Dec 2007
    Broomall, PA
    2,139
    Does the MMM come with a connector for the Battery? Like the one that plugs into the ESC with the Traxxas Male on the wire?
    Also, Does it come with instuctions on how to solder the wires and were to put them?
    And can I use the Stock TQ3 Radio with the Micro 4CH Rec. with the MMM?
    Jan 2008
    696
    Where the wires go is laid out in the instructions.. there is no battery connector since everyone uses a different type, but I would recommend the trx ones. As for using the trx recr with this speed control, I wouldn't recommend it. Thing is that these high voltage esc's have more interferance and the trend has been that there is a lot of glitching with them. Even traxxas is using a new 2.4 Ghz radio with thier castle setup on the new e-revo.
    Reformed nitro operations specialist..
    Oct 2006
    1,260
    must be neil as you cannot pm???
    Dec 2007
    Broomall, PA
    2,139
    So what if I do use it with just two 7 Cell's?
    Dec 2007
    Broomall, PA
    2,139
    The stock Radio and just TWO 7 or 6 Cell NimH's? It's not crazy like 4s or 6s Lipo so will it work?
    Dec 2007
    Broomall, PA
    2,139
    Should I get the MMM Combo with the 2200kV Motor or the MMM Combo with the 2650kV Motor?
    Dec 2007
    Broomall, PA
    2,139
    I guess the 2200kv. So what happens if I used the stock radio?
    RC Turnbuckle Jr. asheck's Avatar
    Nov 2007
    Kansas City
    7,361
    Yes you want the 2200,it's a 74mm can.The stock radio might work fine,or you might have problems,hard to say till you try.
    _
    _
    _ 3 lines are all that's allowed in a sig.
    May 2007
    Kerrville Tx
    4,997
    i would wait on the radio just buy a fail safe so it doesnt runnaway on ya
    http://www3.towerhobbies.com/cgi-bin...?&I=LXHLV3&P=7
    wait for the traxxas 2.4ghz
    Dec 2007
    Broomall, PA
    2,139
    I already have a fail safe so I'll hook that you and get a DX3S (Yes S) eventully.
    May 2007
    Kerrville Tx
    4,997
    why? get the futaba its cheaper!
    Dec 2007
    Broomall, PA
    2,139
    The DX3S is better. IMO
    Sep 2004
    44
    Hey, cool I just did a google search on that. DX3R is pretty awesome but it lacks the telemetry my Nomadio has. Since Nomadio has been concentrating on military gear it has been hard to get receivers for their gear and my React was pretty much on the fritz from day one.
    A Spektrum with telemetry is like a dream come true!
  33. #33
    Dec 2007
    Broomall, PA
    2,139
    Quote Originally Posted by Akirasoft
    I know. The DX3S Are sway bars worth it? I also don't know if the MMM + Stock Radio will work? Should I JUST GET the MMM Combo or JUST get the DX3S? I'm just getting a 700-HO also for the Snow but don't know weather to get the DX3S or MMM Combo.
  34. #34
    Dec 2007
    Broomall, PA
    2,139
    Would I get more run time with a Single 700-HO than with 2 Titans?
  35. #35
    Sep 2008
    Schuyler, NEBRASKA
    556
    motor doesnt matter really on run times, its gearing and what batteries you are using. You will get more torque with the HO.
  36. #36
    Dec 2007
    Broomall, PA
    2,139
    Is it worth getting the Single 700HO? Or will the Titans be ok for the Winter?
  37. #37
    Sep 2008
    Schuyler, NEBRASKA
    556
    Well im sticking with my titans for the winter just cause im going to get the BL system in spring/summer. But tbh i have heard great things about a single HO and for how much they are i mean you might like it a little more than the titans. If you are going BL then id just stay with titans and then get BL in the spring/summer. CANT WAIT FOR THE SNOW!!!!
  38. #38
    Dec 2007
    Broomall, PA
    2,139
    Quote Originally Posted by Shmate
    I'm going BL for Christmas but my Titans went so I need something. Titans? Than MMM Combo for Christmas with some more Lipo's and Nikon D80 Stuff.
  39. #39
    Sep 2008
    Schuyler, NEBRASKA
    556
    Well BL systems are waterproof, and the erevo is going to throw some snow inside the truck and get stuff wet. Thats why im sticking with the titans and stuff cuz its all waterproof. Get the HO if you want, its pre cheap and i know you wont regret getting it. You could get 2 more titans but meh go with the HO or go Bl and just cover up the stuff thats not waterproof. Either way you wont regret what you do. Im going to get lipos and run my titans, then get the BL system. Got a lot of stuff to buy but i know from all the searching and stuff ive read that lipos and BL will be my best investment ever . Goodluck with your conversion and have fun in the snow. I cant wait!
  40. #40
    Dec 2007
    Broomall, PA
    2,139
    Or BL now and Lipo for Christmas.
