Results 1 to 37 of 37
Thread: help
    Dec 2007
    Oregon
    5,177
    help
    I was putting the vxl in the Slash and the pinion gear is stuck on the motor the little grub screw wosnt even in it. Any ideas on how to get it off?
    Amherst New Hampshire
    1,671
    Are you trying to get the pinion off of the Titan? I just put the 23T pinion on the Slash right when I put the VXL in.
    BTW, when did you get a Slash?
    Dontworry,thelightathendofthetunnelisatrain!
    Dec 2007
    Oregon
    5,177
    Its my little brothers Slash he was letting me put the vxl in it. Im trying to get the pinion off the vxl motor.
    1,671
    Uh, hmm, try using a screwdriver as a pry bar to get it off. Why is the pinion being removed anyway?
    Dec 2007
    Oregon
    5,177
    I have tried that to no avail. At this point it dosnt need to be removed but I dont want it to be stuck on it.
    1,671
    Try this: Put the tip of a pair of needlenose pliers around the rotor shaft between the spur and the motor. Then, try prying with that. If that doesn't work, yell loudly and start throwing inexpensive but heavy things around, that's what worked for me.
    Dec 2007
    Oregon
    5,177
    Ok Ill try that tomorrow this is really on good so there might be some throwing involved.
    Jan 2008
    gresham, oregon
    1,958
    my friend trxstampededude had the smae problem with his rustler.
    you have to pry it off, and or put some wd on the shaft,
    Dec 2007
    Oregon
    5,177
    I cant belive I didnt think of trying some wd-40.
    1,671
    Just make sure that you never spray WD-40 when you are doing a soldering project. WD-40 + 40W Soldering Iron = personal flamethrower. Set a piece of sandpaper on fire. Not fun.
    Dec 2007
    Oregon
    5,177
    Sounds like you learned by experience lol.
    1,671
    Yep, and my worktable has the smell of burnt pine to prove it!
    Jun 2008
    In the past I`ve heated the pinion with a lighter,aprox 150/175 deg,then with the needle nose tip between motor and pinion,I push down trying to keep it as straight as possible. It`s poped out every time for me
    Oct 2007
    In the AC system of my LHS...
    1,226
    It's a high price to pay for throwing things around but it does make you feel better...for a while.
    Jan 2007
    Crystal, MN
    1,869
    Quality Hex Drivers. 'Nuff Said.
    BMW E21 323i.. My baby.
    1,671
    Throwing them around?
    Sep 2008
    Edmonton, Alberta, Canada
    1,548
    Quote Originally Posted by Mr. Mukai
    I was working on my car in an weightlifting barbel manufacturing plant. I tried that and pulled something in my back.
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,254
    Quote Originally Posted by rocky8333
    He said the grub screw was not in it.
    Sounds like some thread lock got on the shaft and is holding the pinion on it. Heat has worked for many in this situation but you dont want to use too much. Also I have read of people using the power of the motor to break the bond. Just leave the grub screw out and run the truck. The power of the motor should break the bond between the pinion and the motor shaft.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Dec 2007
    Oregon
    5,177
    Bad news I tried every thing but the heat method because I dont have a lighter. Also Dadx2mj I have used 4 battery packs with it like this and its still on any new ideas?
    Jul 2008
    Perth, Australia
    264
    Much more pinion gear puller.
    HPI Savage Flux
    Traxxas Slash
    Dec 2007
    Oregon
    5,177
    Quote Originally Posted by fb5b
    Theres a pinion gear puller?
    1,671
    How badly do you want to keep this pinion gear?
    Dec 2007
    Oregon
    5,177
    I could care less about it.
    1,671
    Then just dremel-cut it off; being VERY CAREFUL!
    Dec 2007
    Oregon
    5,177
    I have though about it but how it help I would just have two pieces of a pinion gear stuck on it.
    Sep 2008
    45
    heres an idea. if you have a two pieces of metal, place those between the pinon and the motor. follow? you know, follow this awesome little drawing... but tap the end lightly...
    (Sorry in advanced, im sure this is bigger then what the forum rules allow, not computer savy to much when it comes to this) i also just posted the link if the mod's want to delete just the pic
    oh that thing thats supporting the motor and the 2 pieces of metal is a vise, just incase someone wasnt sure...
    <a href="http://s212.photobucket.com/albums/cc224/mtnbikerfitz/?action=view&current=ScannedImage-2.jpg" target="_blank"><img src="http://i212.photobucket.com/albums/cc224/mtnbikerfitz/ScannedImage-2.jpg" border="0" alt="Photobucket"></a>
    Dec 2007
    Oregon
    5,177
    That might work Ill try that.
    Sep 2008
    45
    im some wont approve of this, but it shouldnt have an affect on the motor since there is not a solid surface below the motor. but if you do try this, make sure you do it LIGHTLY. Good luck
    1,671
    I personally would use a C-clamp to hold the gear directly, that way you don't hit the vice underneath.
    Sep 2008
    45
    you could do that, but with the vice, it is mounted to a solid surface. it would be like trying to hammer a nail in a board that you are hold, the impact of the hammer would be too great for you to be able to hold in one place. just put some towels underneath the vice, so if pinon gear comes off the motor wont impact on a hard surface.
    Jul 2008
    Perth, Australia
    264
    Quote Originally Posted by Cynix
    http://rcmarket.com.hk/product_info....oducts_id=1007
    HPI Savage Flux
    Traxxas Slash
    Sep 2008
    45
    that would work.
  33. #33
    Dec 2007
    Oregon
    5,177
    It looks like it would hopefully I can get it off without having to spend 15 dollars though.
  34. #34
    Sep 2008
    45
    the idea that i drew up should work. same principle as the puller. just with a hammer...
  35. #35
    Mar 2003
    Wherever the road takes me.
    36,879
    You should be able to pry the pieces off if the pinion is cut in half.
    Sounds like that pinion gear is really on there!
  36. #36
    Dec 2007
    Oregon
    5,177
    Ya its is I hope I will have time to try and get it off today.
  37. #37
    1,671
    I still swear by the dremel (which my dad broke, )
