I just put these on my Jato.
The instructions say to fill the diff with 30wt shock oil. They say thats whats in it from the factory. Does that sound right? Shouldn't I be adding diff oil? Does it make a difference?
Race Revo, Street Jato
Make tons of difference , 30wt in a diff is way too thin!
You can run 120k diff oil in the diff. even higher.
World fastest E-revo 91.2mph / Revo 75mph
ABmods
stock come w/ 30wt, if you run your Jato on-road most time, go for 50wt or thicker. if you like off-road bashing, go for 10wt or 20wt. The thinner fluid work great at getting the power to the ground on a variety of surfaces.
My Jato use 10wt only...........I'm a heavy off-road basher!!!![]()
Slash PE & Ja-two.
But my question is, can I use shock oil in the diff instead of diff oil? Thats what the instructions say to do.
I put in 30wt shock oil in the diff. Is that ok or do I need diff oil?
yes you want to use silicone shock oil
but iv used everything form baby oil to 20/50 motor oil
It is not 30wt, its 30k wt! any yes I would suggest using the Diff oil!
the thinner the more the differential will slip....
the thicker will slip less thus turning the tiers more, more wheel spin.
Baby oil sounds pretty smooth... LOL
Somebody should try a mixture of petroleum jelly and vicks and tell me how it goes...
#mphModel: 60NR, 62Jato, 51Revo, 36Slash, 35MiniT
Do those steel drive shafts put too much stress on the gears making it more likely to strip the trans gears?
Jato o.s.21TM,19/36,7075-T6 Chasis/DC Res
No. I have run the traxxas CVD's with an AB modded .21TM and am AB drag modded Picco/JLR.12. Only a BB engine will have more tork than the modded .21TM and nothing has more rpm than the JLR.12 at 50K+ and my CVD's are in perfect shape. Less rotating mass and looks much better than the plastic.
G4/V15
IGT2/P9R
Revo/.21TM
Walbern PRO-MOD
i believe it says 30 k weight defiantly stick with diff fluid shock oil is to thin
Losi eight E
Mini revo/rusty
t4/b4
i filled my diff a while ago with "Kyosho silicone oil 30000"
so what is this is this 30k or 30wt or something else??
don't mean to jack your thread.
I was looking into buying those traxxas cvd's. So this thread is very informative.
Jato 3.3 with a few upgrades...
30wt & 3k are big diff.
Slash PE & Ja-two.
So what it better to run?
30wt silicone or diff oil?
Im pretty sure 30wt shock oil is not the same as the 30k diff lube. Use the Diff oil
2CH3NO2 + CH3OH + 3O2 → 3CO2 + 5H2O + N2 =Jato Fun
actually the differential is filled with 10K wt. diff oil...Originally Posted by RC-Crazy
from page 44 of the manual...
Originally Posted by from page 44 of the owners manual
you are right they are not even close to the same...Originally Posted by clegg
30Kwt = 30,000wt oil... so as you can see 30Kwt oil is 1,000 times thicker than 30wt...
EDIT:
just for comparison 30wt oil is thin, like regular motor oil...30Kwt oil is really thick, like the consistency of molasses...
"Growing OLD is mandatory, Growing UP is optional"
Yes there is def a huge difference between the two and I would imagine that the shock oil would problably not do anything for the diff. (except maybe provide some sort of lubrication) I am running traxxas' 500,000wt diff fluid in my jato's. It pretty much allows the jato to have possi traction, ,meaning the rear wheels spin at the same rate and provide equal amounts of power to each tire no matter what conditions you are running in.
Jato25n33 You sent me the wrong parts and you have your PM's shut off...... Get back with me would ya?
V-Spec Revo, UE EXT Thunder SM
500k wow what surfaces you run? with the amount of power the jato puts down i would think anything less than 50k or 70 would be useless. That Jato just manditorily seems to break a driveline part or two every so often. Almost like scheduled maitenance. It comes with the territory.
I use 700,000 wt in my diff. It's thicker than cold honey.... It'll lock it up just right!The jato Diffs out to much to use low weight oil in the diff if you ask me. Over rough terrain it'll diff out so much you practically stop some of the time!
