Results 1 to 11 of 11
    Aug 2008
    Central Jersey
    89
    Revo Shock Mod For Slash
    Got My New Gtr Shocks(30 or so bucks off ebay) Today There Really Nice, Stock, they fit the front perfect, Rears Are A Bit Too Short For My Liking,(can Be Used ) All You Have To Do Is Take Out The Top Ball joint, And Put Your Bottom Ball joint From The Slash In place Of The Revos, <--- For Both Front/Back. I Modded The Rears By Taking Off the Rod End And Putt On A Ti rod End In Its Place(there longer) But The Only Ones I Had Laying Around Were The Ones From The Slash So The Thread Hole Is Bigger On The ti rod So I Cut Off The End Of A Zip Tie Because it goes from really skinny to fatter put the fat side on the bottom And screwed the shock in. it holds Really Good (tried pulling it apart)But It Didn't Budge I'm Gonna see if i can find some longer rod ends that fit the revo shocks if not i may try something like shrink wrapping the threads and see how that works but for now its a perfect fit for the rears, hopefully i sprung up some ideas and maybe we can Make some good Mod shocks for the slash. btw I Had Them On It, It They Compress very nicely they will go all the way down till the truck bottoms out, only problem is all the tuning one will have to do to get it perfect( shock oil weight Piston Holes Springs?). Pics Anyone?
    Edit: i think the rears will be perfect oil weight and spring wise fronts are too stiff ( i have a 11.1v 8k batt also the stiffer rear is needed
    Stock Revo Ball End, Stock Revo Shock - Slash Ti rod Ball End, Modded Revo shock, Stock Rear Slash Shock
    Front Revo Slash Shock, Rear Modded Revo Slash Shock
    Jul 2008
    Michigan
    1,319
    sweet^^^^^^^^^^^
    Yes, I drive an electric converted Nitro Hawk.
    Jun 2008
    Orange County, CA
    786
    Twisted, in the process of throwing the same shock set up on my street Slash. Had to lengthen the rears of course, we'll see how they hold up with just loosening the rod ends. I've run it only with blue dot, Jato springs in the rear and some Integy springs from piggybacks i had laying around for the front. So far so good in terms of road behavior, there is no doubt that some fine tuning needs to be done, but all in all pretty good set up for what I'm gonna use it for. Are you gonna be hitting the dirt with set up??
    NOT A MAMBA, NOT A MAZDA--TEKIN RX8-problem solved
    Aug 2008
    Central Jersey
    89
    Yea Dirt Is Where Its At
    Jun 2008
    Orange County, CA
    786
    I hear you on that one. I wanted to try this mod out first for the street and see if it was worth doing on my other Slash. Tell me your gonna make some mods to the springs and shock oil at least, that thing would bounce like a rubber ball with those REVO springs on it?
    Aug 2008
    Central Jersey
    89
    i will Change the fronts the rear possibly when i drop it the rears are nice, fronts are too stiff not to mention i have to add all the electrical stuff so i think i may keep the rear the way the are.
    Aug 2008
    Central Jersey
    89
    Shrink wrap works great too! its really on there
    Jun 2008
    1,164
    They're not that much shorter. I thought they were for some reason.
    English. It's your language. Learn to type it.
    Jun 2008
    Orange County, CA
    786
    The fronts are dead on in length, but like TwztD shows, the rears have to be lengthened quite a bit, his Jangified rear set up with the zip ties and shrink wrap looks like it should work. Gonna give it a go when I get home.
    Aug 2008
    Central Jersey
    89
    also fuel tubing works cut it to fit in the hole and start screwing it in! (my fingers are hurting lol)
    so cal
    554
    i was watching a thread on a different forum and what they did for the rear was use these (i'm pretty sure) shafts. these it looks like they're longer than the revo shafts and you'll have to use a nut to hold the piston
    "That don't make NO sense!"
