Results 1 to 14 of 14
    Aug 2008
    Canada B.C.
    332
    Will these two Pinion Gears fit
    I have 2 pinion gears 17t and 10t from other rc's could I still use them on the slash or do I have to buy one for that motor
    Jun 2008
    Las Vegas
    286
    Slip it in and see if they Mesh...
    Slash - Agent ORANGE - The Aluminum Dream Machine
    Jun 2008
    397
    if they r 48 pitch they should mesh. just watch temps! my 16t gives really good acceleration, but top end suffers. don`t really know if 10t will be too small or not.
    Long live Duck Tape!
    Aug 2008
    Canada B.C.
    332
    how can i tell if its 48 pitch and i dont know what 48 pitch means
    Jun 2008
    397
    see CHECKMATEofLV`s post then
    Aug 2008
    Canada B.C.
    332
    i check CHECKMATEofLV posts i got nothing out of it thanks thow
    would there be much differents from 18t to 17t pinion gear
    Jun 2008
    397
    not really. i think he means to slide the pinions onto the motor, while installed, to see if they mesh with the spur gears.
    Mar 2003
    Wherever the road takes me.
    36,879
    The easiest way to tell if the gear is a 48-pitch gear is to simply compare it to the factory spur or pinion gear.
    There would be a slight difference between a 18 and a 17 tooth gear... not huge, but it should be noticeable.
    Aug 2008
    Canada B.C.
    332
    i'll go check then i'll try it out thanks lot guys
    Jan 2008
    Oil Country
    1,388
    See if the teeth are different sizes, like this
    Incorrect:
    Correct:
    Notice the teeth on the first one are larger, and shaped differently.
    Violence solves everything.
    Aug 2008
    Canada B.C.
    332
    cant see the pic..that sucks
    Aug 2008
    Canada B.C.
    332
    it could be my computer because lately some pics dont show up there just little red x's thanks thow
    Jan 2008
    Oil Country
    1,388
    They are both 22 tooth gears, but the top one is 32 pitch, making it uncompatible with the Traxxas spurs.
    Aug 2008
    Canada B.C.
    332
    if i gave you my e-mail could you send them to me that might work
