    Aug 2008
    Canada B.C.
    332
    Need help fixing stripped screw hole?
    One of the two screws hole on the gear cover (the little one) is stripped don't know how to fix it properly
    Feb 2008
    Fort Smith, Arkansas
    291
    Probably the simplest way to do it is to just use a slightly larger screw.
    Aug 2008
    Canada B.C.
    332
    okay thanks guys
    Amherst New Hampshire
    1,671
    The gear cover screws aren't that important anyway. They usually will stick inside even if the tranny case is stripped.
    Dontworry,thelightathendofthetunnelisatrain!
    Aug 2008
    Canada B.C.
    332
    i'm sorry the spur gear cover
    Mar 2003
    Wherever the road takes me.
    36,850
    Try putting some CA glue down the hole and then install the screw. The CA glue will form threads around the screw inside of the hole, and it should help keep the screw in there better. It's not a permanent fix, but it works... I have done it a couple of times. .
    1,671
    Huh? That sounds like a good tip! I'll try that next time I strip a screw (and I need some CA glue too.)
    Aug 2008
    11
    Let me know if this works (the glue)... I had the EXACT thing happen to me as well.
