Results 1 to 13 of 13
Thread: smoke
    Jun 2008
    397
    smoke
    my titan lost power, so I replaced it with a peak racing raven 17x2. a few day of running i noticed smoke. originally thinking i toasted the motor. after checking out the motor all seemed well. while runnin today it really started smokin. upon inspection the wires had melted.the esc has 14 guage wires on it. my motor had 16 or 18 guage on it. would that cause a bottle neck, super heating the smaller wires? if that be the case, could I change the wires to a heaver guage. if so would 12 be to big?
    Long live Duck Tape!
    Mar 2003
    Wherever the road takes me.
    36,990
    Did you change your gearing when you installed the 17-turn motor?
    Jun 2008
    397
    Jan 2008
    Oil Country
    1,388
    Did you break it in?
    Violence solves everything.
    Jun 2008
    397
    yes! yes! yes! u all r missing the question!!!
    Jun 2008
    1,164
    Quote Originally Posted by bde742
    Isn't it amazing how that happens? It happens all the time around here.
    I'm not sure if the wires could have melted by being only a few gauges smaller. But yes you can change them. Assuming they are connected to the end bell just like any other motor, just heat up the solder until it flows and the wires will disconnect. Then resolder some new ones.
    12 would only be too big if it gets in the way.
    English. It's your language. Learn to type it.
    Jun 2008
    397
    thanx 4 answering my question with out a question
    Aug 2008
    17
    the question doesn't matter if YOU are missing the issue at hand - overearing
    Jun 2008
    397
    Quote Originally Posted by SLASH-&-BURN
    what is overearing? and yes the question does matter!! it was my question!!!
    I didn`t ask about gearing. I asked about wires!!! So if YOU can`t help, don`t!!!
    Jun 2008
    1,164
    what is overearing?
    That's a congenital problem with over sized ears.
    Also known as, Dumbo Syndrome.
    Mar 2006
    MI
    4,478
    Quote Originally Posted by Slasher
    Thank you for clearing that up.
    I tried being reasonable, I didn't like it.
    Amherst New Hampshire
    1,671
    Anyhow, since it seems that you aren't getting any help from the others except Slasher, I'll try to clear some stuff up. When you are working with wiring, it is like water through a pipe, too much water through a small pipe, and the pipe bursts. If you run a larger diameter pipe, then you shouldn't have a problem. 12 guage wire should be fine (it works for the VXL, I'd be surprised if that melted.)
    Now go have some fun with your Slash!
    Dontworry,thelightathendofthetunnelisatrain!
    Jun 2008
    397
    thanx, Mr. Mukai. You`re correct. Slasher is the only one offering any real help (except you).
