Results 1 to 21 of 21
    Jul 2008
    27
    Exclamation Stripped glow plug
    Just as the title says I stripped out the glow plug on my TRX 2.5 Engine. Being a newbie I am freaking out because I have no clue what to do. Any help would be appreciated. The one part that I do not need help on is telling me not to overtighten it I have figured that one out myself and just need to know how to fix it. Thanks in advance.
    Jan 2008
    Sugar Hill Ga.
    8,378
    Your going to need a new cooling head if you stripped out the glow plug threads. EBay - about $10.00
    RC Turnbuckle Jr. NStampede Freak's Avatar
    Jan 2008
    Catskill mountains, NY
    3,012
    And make sure there aren't any metal shavings on the piston when you take the head off!
    N Stampede 2.5R
    E Stampede VXL
    Tmaxx 2.5
    Putting the water on the hot stuff
    9,706
    If you stripped out the threads, as it sounds like you did, you'll need a new head. Remove it, check the piston and crankcase for any metal shavings and flush/clean it. Put the new plug in (don't overtighten it! Heeheehee--couldn't resist) put the head on and go.
    Lesson learned. And by doing the work yourself, you'll gain a lot of knowledge how the engine works. Do not worry.
    Jul 2008
    27
    Does the new cooling head include the spring that came out with the glow plug when I noticed it was stripped?
    Jan 2008
    Sugar Hill Ga.
    8,378
    Quote Originally Posted by bengalfanmt
    Spring???
    I can't be certain but, It sounds like you may have purchased a used engine/truck and someone else stipped the glow plug hole and repaired it with a Heli-coil.
    You got any pics??
    If thats the case. you can try installing a new heli-coil for the thread repair but they are not easy to come by. I believe the threads are 1/4 x 32.
    I have repaired a few stripped glow holes before and while they will work, Heli-coils tend to leak at the plug gasket and sometimes will back out of the cooling head.
    You're best bet is to buy a new cooling head. No "spring" is needed or involved. If your replace the head I recommend replacing the head gasket as well.
    Jul 2008
    27
    When I noticed that it was stripped I pulled out the glow plug and it had a spring stuck to the end of it. If that is the case would this work to fix it?
    http://search.stores.ebay.com/traxxa...nknownQQsofpZ4
    Feb 2006
    South Arkansas
    44
    There is a small coiled element inside the glow plug.
    Thats what heats up when current is applied.
    Is that what you are talking about?
    Jul 2008
    27
    No that is still their and the glow will light but the coil was on the outside at the base of the threads.
    Feb 2006
    South Arkansas
    44
    Probably a Heli-coil then.
    No, you don't need to save it.
    Yes, those cooling heads on ebay with fix your problem.
    9,706
    I'm not sure about the 2.5 but I assume that it has a head gasket too. See if the head comes with one, if not, get one.
    Jul 2008
    1,067
    I would upgrade if I were you, to the Nove or one of the others
    Jan 2008
    3,012
    Actually, I wouldn't. Aftermarket heads make the engine run too cool so you will never know if you are running too lean.
    Get a 2.5R head off a ebay chop-shop. Cheapest(and really the best) way out.
    N Stampede 2.5R
    E Stampede VXL
    Tmaxx 2.5
    Sep 2006
    Marietta, OH
    3,073
    Yeah, just get a 2.5 or 2.5r head. you don't want to have to lean out your engine to get temps up when those big heads make it run too cool.
    Those who throw dirt are bound to lose ground.
    Jul 2008
    27
    Thank you for all of the help!!!
    Jul 2008
    Cressona, PA
    114
    Or just upgrade to a 3.3 and solve the problem and get bigger engine.
    Upside Down and out of gear!
    Mar 2013
    Unhappy
    hi i did the same thing to my cooling head its only the first couple threads do u think i can repair it with tap kit
    2,215
    Quote Originally Posted by djthekeith View Post
    No buy a new one
    "I like rc cars"....."WHAT? YOU'RE KIDDING!"
    9,706
    Agreed. You can get a new head for pretty cheap.
    Oct 2013
    Quote Originally Posted by Snook Man View Post
    ive got an os .30vg in my revo. i bought motor used from a friend and new head is $75 on ebay or $78 from store. ive found slightly bigger glow plugs but cant find a tap any where to make plug fit
    Oct 2005
    South Florida
    18,515
    Quote Originally Posted by nate_dawg26 View Post
    I don't know which Ebay you are looking at but you can get the 2.5r Powertune cooling head for under $40.00 on Ebay Buy it now and shipped....
    I don't get the point of tapping a head for a larger plug... I don't think that's going to run very well.
    Robin Williams
    He will be greatly missed...
