+ Reply to Thread
Thread: Which is faster
    Jul 2008
    Corpus Christi
    Which is faster
    A 2s lipo or 7 cell pack
    South Texas Hobbies - we make you go faster
    Registered User
    Jul 2006
    Montana
    4,979
    A 2s lipo is about the same voltage, but it will provide a ton more amps. Amps aren't too important with the stock setup, but if/when you go brushless there is a HUUUGE difference.
    EDIT: Speed on stock setup should be pretty much the same. The lipo will weigh a little less but I doubt you'd notice.
    somewhere in Mo
    4,809
    A quality 7-cell will beat a 2s lipo anyday. 2s lipo voltage is 7.4 volts, 7-cells is 8.4. Its close, but 7-cell still wins.
    An injured friend is the bitterest of foes
    Registered User
    Jul 2006
    Montana
    4,979
    Quote Originally Posted by VXL Beast
    Correction: A fully charged 2s lipo is 8.4v on the nose. And with anything that pulls any decent amount of amps the lipo will hold up better under load. The EnerG 4600s are pretty much the exception (they hold voltage longer than most lipos, but when their amps dump they dump pretty hard).
    Mar 2007
    737
    The lipo is going to be about the same because the 7cell will actualy be closer to 9 or so when fully charged. But will drop some what with a load. Chances are you will get a lot higher mah on the lipo therfore a much longer run time! So lipo is the way to go because it will be about identical in speed and power and as I said longer run times!
    The only down side is much more expencive since you must buy a lipo charger and the batt!
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    19,716
    When I went from a 6 cell nimh to a 2s lipo the weight savings was one of the first and biggest things I noticed.
    To the original quesiton a lot depends on which 7 cell and which 2s you are talking about. I have a SMC 5000mah 2S that runs faster than my 7 cell Ener-G packs the 8 cell Ener-G pack beats the 2s lipo but not by much. In fairness the 2s lipo is new and fresh and the Ener-G packs have seen a LOT of cycles and close to the end of their life span.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-QR-1
    SPC Lipo Power
    Dec 2006
    2,468
    Not other lipo vs nimh thread
