+ Reply to Thread
Results 1 to 14 of 14
    Jul 2007
    connecticut
    1,092
    problems running lipo lvc
    hey guys im just set up my slash with a 5000mah 2s lipo and the required lvc its a novak 2 cell lipo smart stop my problem is that on forward the motor stumble then takes off unless i give it gratual throttle in reverse it works fine though has any one had any similar problems ? also i dissconected the lvc and the truck runs fine and i tried two different lvcs and the same problem occurs ......any remedies ?or do i have to just slap in a vxl setup lol
    drive it like you stole it !!!!!
    Mar 2005
    Des Moines
    2,554
    What LVC are you using? Do you need to "calibrate" it or anything?
    It also could be that the battery voltage dips below the LVC threshold when you take-off (which is where the largest currents are) causing your problem. Although, 5Ah lipo voltage shouldn't dip that much, especially for stock motor/ESC...
    Jul 2007
    Charlotte, NC
    1,243
    The Novak lvc does not work properly with the XL5 unfortunately. If you search through the threads on this forum you will find some other discussion on it, including a suggested alternate brand.
    Traxxas racing!
    Jul 2007
    connecticut
    1,092
    Quote Originally Posted by BrianG
    I did state the type of lvc in the post ......has anyone run the novak and have any insight ? Thanks in advance
    Frog season opens at sunset June 30th and closes October 31 every year.
    864
    I did see on there site there's a set up button on it, have you tried that?
    Get your vote on.
    Jul 2007
    connecticut
    1,092
    Quote Originally Posted by Garbage_Man
    Yes I programed it and followed all the steps in the instructions
    Jul 2007
    connecticut
    1,092
    Ok gentlemen I found the problem ........don't use the novak smart stop with the stock slash esc it won't work apparently it been an issue I called novak tech support and the tech informed me that its a common issue with the incompatability with the esc they are looking into it .........sooooooo don't use the *novak smart stop lipo lvc * vxl setup here I come!!!!!!
    Sep 2004
    nj
    1,090
    Yep don't work on a XL5!
    Thanks
    Z....
    864
    Quote Originally Posted by MRB1GG
    Bummer. Nothing worse than finding out after the fact...
    Get your vote on.
    Jul 2007
    connecticut
    1,092
    Yeah and to think I bought two so now I'm out the 60 bucks lol
    864
    See if you can return them otherwise get them up on ebay asap.
    Get your vote on.
    Jul 2007
    connecticut
    1,092
    Didn't think of that but imma have to try it thanks!
    Sep 2004
    nj
    1,090
    Some guys told me on the rustler board to use a lipo LVC they showed me some they light up and beep really loud when your set voltage cut off gets reached..
    LOOK HERE for them
    http://monster.traxxas.com/showthread.php?t=426843
    Thanks
    Z....
    Jul 2007
    connecticut
    1,092
    thanks alot for the advice guys i just went and installed a vxl setup biiiiig difference even with only a 2s lipo woooohooooooo
