Results 1 to 12 of 12
    Jul 2008
    Munich, Germany
    51
    Problems to adjust slipper clutch
    Hi,
    the slipper of my slash was too strong out of stock - so i tried to loose it with the 4-way wrench.
    But trying that, the wheels are turning. Holding the wheels on the ground i was not able to loose the slipper its was too strong..
    What did i make wrong?
    Thank you
    Mannie
    Frog season opens at sunset June 30th and closes October 31 every year.
    864
    Grab the back plate with pliers, then use the wrench on the nut.
    Get your vote on.
    Jun 2008
    1,164
    It seems a large majority of Slash owners on this forum are experiencing the same thing.
    Just turn it with all your might. Try holding the spur gear instead of the wheels. If you hold the wheels and the clutch ends up being tighter than you first though, who knows, maybe you could mess up the drive axles.
    English. It's your language. Learn to type it.
    Jun 2008
    27
    I actually had the same problem. I ended up flipping the truck on its side and put it on my lap. I kind of held the tires down with my left arm, used my left hand to hold the spur gear and my right hand (I'm a righty) to loosen the clutch. I found that (for me, at least) it's a lot easier to loosen it when you're looking down on it then when you're doing it from the side.
    Jun 2008
    Orlando, FL
    447
    I stick an Integy driver in the drive line to lock it up... works nicely...
    Work smarter, not harder my friends.
    864
    I use pliers to lock mine. If I don't lock it all it does is slip.
    Get your vote on.
    Jul 2007
    Charlotte, NC
    1,242
    It helps to use something with the nut driver to get more torque on it. You can put a small screwdriver or something similar through the side arms of the four-way nut driver and use that to turn it.
    Traxxas racing!
    Dec 2006
    Central New Jersey
    835
    Having it locekd down completely from factory? Is this what you guys have found? I just adjusted mine today. It was locked down completely.
    MARBETH Racing
    Jun 2008
    Orlando, FL
    447
    Quote Originally Posted by NJT-MAXX
    Yeah cost me $3.99 for a new spur...
    Consider yourself lucky...
    864
    I think they took the trans from the VXL production line. So they were set really tight. I dunno.
    Get your vote on.
    Apr 2008
    Eugene, Oregon
    263
    I had to wrench on mine with an actual socket wrench to break the nut loose so it would turn. It was REALLY stuck on there, definitely not "RTR" in the sense unless thats what they wanted the slipper set at for the Titan, which I never used anyway, straight to VXL for me.
    Apr 2007
    400
    Still running mine like it was set at the factory and havn't had any problems. But then again I usually run a really tight slipper on all my stuff anyway.
