Results 1 to 12 of 12
    Apr 2007
    In a box on Hwy 64.2 - Bashin' With Mike, Pat & Brad. hey i didnt start this.
    7,488
    2 stripped spurs in no time at all
    well had the slash out today. and stripped my only 2 spur gears i had. not sure what the cause is. possibly getting stripped due to the gear cover not being installed.
    ADDICTED TO THE TWILIGHT SAGA
    Jul 2004
    Ft. Smith, AR elevation: 449ft
    694
    thats prob a big part of it, also check your slipper clutch, and if your jumping dont be holding full throttle when you land
    .___/ ```i____"""""""ex racer
    [_^______ ^ _]Now RCdrifter & Revo
    .( o )____( o )___Backyard basher
    Jun 2008
    Orlando, FL
    447
    Quote Originally Posted by 69Malibu
    hmmmm... what are you running again? brushless???
    on dirt or crete??? why are you running with the cover off?? lost it? forgot it?
    Also, did it flat spot it??? mine has a total flat spot about 1" on it...
    it's like it just took all the teeth off in that section...
    Registered User
    Jan 2008
    Traverse City, MI
    8
    Loosen the slipper a little, mine came locked down. I also installed the RPM gear cover. You have to do some dremeling on the rear bumper to get it to fit, but it is a totaly sealed unit unlike the stock cover. Also the stock pinions are made out of soft metal and wear real fast if you get anything in there, I upgraded to some robinson racing pinions.
    Jul 2007
    Charlotte, NC
    1,242
    Most likely either the mesh was too far apart, the motor screws were not tight (which allows the mesh to come apart slightly), or a bit of dirt in the pinion. I clean out the pinion with a small flat screwdriver now and then to be sure it stays clean. A little rock or bit of sand in there will wreck a spur quick.
    Traxxas racing!
    Apr 2007
    7,488
    i will check everything suggested. and will also perform full maintenance on the motor. i had no air time at all. thinking msot liekly slipper, dirt, and mesh all had a part in destroying both gears.
    Aug 2007
    Fremont, Ca.
    944
    If your going to run with the gears exposed you might want to try jato gears instead. I have yet to strip a 32p pinion or spur in either my rustler or slash.
    [QUOTE=Billstmaxx]if the water can't get out how does it get in??[/QUOTE]
    Apr 2007
    7,488
    i would need a similar gear setup to an 86 spur and 17 pinion.
    Aug 2007
    Fremont, Ca.
    944
    58 spur and 12 pinion is like 86 and 17.5 so it's possible to do.
    Registered User
    Jul 2006
    Montana
    4,979
    Check your bearing. I've had my Rustler strip 5 spurs in one day before I finally wisened (is that a word?) up and checked my bearing. Sure enough it was bad.
    Jun 2008
    Orlando, FL
    447
    Quote Originally Posted by Unsullied_Spy
    Hmmmmm mine seems a little rough... I run with the cover on, so I'm not sure how it got kinda tweaked like that...
    I guess I should replace it too???
    Registered User
    Jul 2006
    Montana
    4,979
    Quote Originally Posted by SirPsycho
    They wear out from use, they see a lot of RPMs so they wear fast. I typically try to check mine once a week, but I use mine a lot.
