Results 1 to 21 of 21
    lubbock, TX
    348
    What Hop-ups To Buy
    got a slash after seein my dads, ive got about $350 a main has them in stock and shipping is about 16 bucks, so with what i have left what should i get, like carriers or shocks, im gonna put a max and velineon in it, i was thinkin big bores and a set of aluminum casters all around, is the al. steering linkage necessary? looks cool even if not LMK, moneys burin a hole, lol
    Platinum E-REVO
    FT T4 - Novak Havoc
    Apr 2007
    In a box on Hwy 64.2 - Bashin' With Mike, Pat & Brad. hey i didnt start this.
    7,488
    it aint needed. instead look into rpm arms for it.
    ADDICTED TO THE TWILIGHT SAGA
    Jun 2008
    1,164
    I would also recommend the aluminum steering knuckles (aka bearing carriers). On my first few runs after I got the truck I never did any jumping. Just fast driving over really rough terrain. I still bent the caster screw-pin which lead to a huge gash in the stock carrier.
    You'd only need 2 caster blocks. The rear axles don't use them. I still use stock knuckles in the back, too, because without the stress of steering linkage bending and moving, those parts aren't subject to breakage.
    Maybe get a good 7 cell pack. Otherwise, I'd leave the stock power system in place. You'd be out of your budget with a new one any way. Big bore shocks are some what pricey, too.
    Have fun with it before you start making all kinds of changes. Save up that money for what you discover you really need.
    PS. For aluminum caster blocks, you'll need king pins.
    English. It's your language. Learn to type it.
    PA, USA
    909
    When I get the Slash, here's the list of parts I'm going to put on it:
    RPM: front a arms, front/rear shock towers and bearing carriers
    TRX: aluminum bellcrank and caster blocks (w/ VXL kingpins)
    I will also be purchasing a Kimbrough #124 servo saver (gas truck servo saver), since the stock unit lacks a little to be desired.
    Personally, and it may be different for you, but I try to stay away from as much aluminum as possible. Caster blocks and bulkheads (along with the FLM tranny case) are the exceptions, but as far as arms and shock towers go, I prefer to use RPM products.
    Traxxas: Stampede, E Maxx
    Losi: Muggy
    Jun 2008
    Lost & Found on the intersection of Walk & Don't Walk
    1,614
    Quote Originally Posted by 69Malibu
    why does everyone say that? I have 4 trucks, the oldest one is about 4, and I havn't had problems with the stock. Is it wider?
    NOBAMA '08 Welcome to the Greatest Dprsn.
    Jun 2008
    1,164
    Nah. RPM just has the rep for not breaking.
    I broke one rear a-arm when I had a Stampede. But it took lots of hitting rocks (in a huge pile of rocks) underneath to break it.
    Stock arms should hold up for a very long time.
    Apr 2007
    7,488
    msot of the times when something happens to my arms it is holes being ripped apart. i just tried to fit a set of nitro arms on my slash and wasnt happy with no options for shock positions.
    lubbock, TX
    348
    i already have the b/l setup, we jsut put my mm and c4 5700 in his and it rips, i just know i hated the shocks on my t-maxx and these are ecentually the same, was gonna get rpm's, and the front caster blocks i guess, what about trx turnbuckles and camber links? anybody run them on their pede or rusty?
    Platinum E-REVO
    FT T4 - Novak Havoc
    Jun 2008
    Alta Loma,CA
    24
    I have had my slash for 3 days. Was palying hard on my friends BMX park. First thing I did was pop the rear shock caps. Filled with 40wt and got back to it. Had to stop when one of the shock shafts bent. My friend has dont the same already and on his recomendation I will be getting aluminum shocks for mine. Just need to figure out which ones to get.
    The shock towers also seem a bit flimsey to me, so I may get those as well.
    Slash - stock for now.
    RC10 T4 - Castle 5700kv
    PA, USA
    909
    I wouldn't mess around with TRX camber links/turnbuckles. The stock ones are actually better than the TRX ones. Odd as that may sound, but steel > aluminum in the strength department. That, and IIRC, the TRX links are hollow.
    For shock towers I highly recommend the RPM units. Since there's room in the front, get the nitro 'Pede/Ruster front shock tower because it has a cross member linking the two sides. It'll be 100x stiffer than the stock noodle. The rear is also much stiffer than the stock unit, plus I think the RPM towers look better.
    Losi: Muggy
    Oct 2007
    Appleton, WI
    105
    I have to agree with Slasher on this one, keep it stock and run it to find the things you really need to upgrade. I have found the the shock caps pop relatively easily, I replaced with Aluminum Shock caps and havent had a problem since. I also put heavy grease in the Diff to keep it from unloading the inside wheel on turn (keeps the accidental donuts to a minimum). I also dropped a VXL in it, which is fun, but not necessary, the 12 turn on a 7 cell is definitely enough for the intended use of the Slash. Just my 2 cents, hope this helps.
    Time flys like the wind, fruit flys like bannanas
    lubbock, TX
    348
    WELL, i confiscated my dads since hes gone and ordered him a new one.. lol, put the mm and a c4 5700 in it, on 2s lipos it rips, i ordered a epic 19turn and tried it out while i was goofin with it today and its a drastic improvement over the titan, but what does anybody and leave stock anyways, lol, so when his gets here i can put that motor on for him and then show him mine/his brushless and lipo'd its his first rc so I'm sure he will be thrilled with it that way, i was thinking of buying one then he did and had it shipped to me since he is working nearby right now, these things rip, lol i think its faster than my xxx-t with the vel, and its geard 26-80 on the same batts, but the motor is bigger, but no matter what was in it, it was a blast to drive!! thanks guys im ordered out, i got some 3s lipos and the al front end stuff, will get rpm's locally in a few weeks, this hobby takes too much money!
    Platinum E-REVO
    FT T4 - Novak Havoc
    Jun 2008
    7
    I have already replaced the front a-arms with Blue RPM A-Arms. Look at getting an extra rear skidplate (The stampede rear skidplate works). I also added big bore shocks on the front and I have seen a really nice improvement. I am looking into better tires now (my original ones are wearing down bad).
    Jun 2008
    Seattle
    767
    Link for the big bore shocks?
    popped my stock cap - that front end takes a beating at 30 mph thru the gravel/rocks/dirt - but a good hit on an unexpected boulder and bam! back to the shop.
    EREVOs, Slashes, 1/16 Slash, EMAXX, VXL Villain
    Apr 2007
    7,488
    oaky i got the traxxas castors, steering bellcrank, and a 19t modified motor in my slash and the truck really wants to move. here are some pcis of the truck:
    Jun 2008
    Orlando, FL
    447
    Part numbers???
    Jun 2008
    24
    69malibu, how did the traxxas castors and steering bellcrank fit? I just picked them up myself and I'm wondering if I needed anything else to make them work or if they are direct bolt-on parts. Thanks
    Jun 2008
    1,164
    You'll need king pins with aluminum casters. The supplied screw-pins are too wide.
    Jan 2008
    Austin, TX
    201
    I re-used the silver hex-head screw-in pins from my Slash in my Traxxas red aluminum caster blocks and they fit perfectly... they are pre-threaded from the bottom. I wonder why yours didn't work? I also installed the aluminum steering rack, but I had to shave about half a millimeter from the plastic to keep it from rubbing. Everything works great!
    Dirk
    Slash,#3905 E-Maxx,Rustler,Stampede,9 more
    Apr 2007
    H-town, TX
    1,604
    Quote Originally Posted by Seattle Slew
    http://www3.towerhobbies.com/cgi-bin...BORE&search=Go
    I'd just get the Big Bore caps... They fit on the stock plastic cylinders very tightly, and WILL NOT pop off....
    My Pede http://www.youtube.com/polishdog69
    Jan 2007
    Riptide Raceway Winnabow, NC
    1,864
    Quote Originally Posted by !bungle
    Ditto on both counts. I used the screw in king pins on my red aluminum caster blocks. I also had to shave that amount of plastic from the chassis brace to allow room for the aluminum bell crank. It is perfect now.
    I have also installed red aluminum bearing carriers, red aluminum turnbuckles, and a Swami bar. Next is RPM shock towers and maybe a-arms.
    TR
    To err is human, to arr is pirate!
