    Jun 2008
    18
    Glitching after installing MM 7700
    Droped this esc and motor in my slash and now my range has reduced. When I get to about half a block the car starts to jerk and I lose my signal. Anyone else have this problem? Probably going to upgrade to a 2.4 ghz radio.
    Traxxas Slash w/ Mamba Max/CM36-s7700Kv/7cell Nimh
    Jul 2004
    Ft. Smith, AR elevation: 449ft
    694
    i've herd about glitching with the mm and spectrum and digitail servos on other forums... they said that it was because the rx was not getting enough power from the mm. to check the problem they said to plug in a receiver pack and see if it still glitches...
    hope it helps
    .___/ ```i____"""""""ex racer
    [_^______ ^ _]Now RCdrifter & Revo
    .( o )____( o )___Backyard basher
    Jul 2007
    Charlotte, NC
    1,242
    Spektrum makes a receiver capacitor to prevent that, but I'm not sure if it works on any receiver or only their own. That's almost certainly the issue though - too much power draw from MM
    Traxxas racing!
    Mar 2006
    MI
    4,478
    Sounds like he is still using the stock radio, not the spektrum.
    I had similar problems when I upgraded to a 5700 and the spektrum radio solved the problem.
    I tried being reasonable, I didn't like it.
    Jun 2008
    18
    Yes I am still using the Traxxas TQ radio. Probably gonna get a Futaba 3PM 2.4 ghz or an Airtronics MX-3 FHSS 2.4 ghz.
    Jul 2004
    694
    i am using an older spectrum and everything else stock with no problem... sry that doesnt help
    22
    had the same problem when I got my mamba. Try twisting the motor and battery wires around like a spiral. dont know what it does but it gives a bit more range.
    15,999
    Braiding is better than twisting. Yes, the MM motors put out a bit of interference along with all that power. I had the same problem and I bought a DX3.0 to solve it. I also have the Spektrum "voltage protector" capacitor, but haven't used it since way before the new radio.
    Alt-248 on the number pad =
    May 2007
    535
    You ned a ferrite ring or a new radio. I've been there.
