Results 1 to 18 of 18
    Jun 2007
    Springfield, VA
    1,580
    MMM with Titans?
    I'm not sure if this has been discussed before or not, but would it be possible to drive the two stock Titans with a MMM ESC, assuming you wire them correctly?
    MMM/2200 powered E-Revo - sufficiently excessive
    Jan 2007
    Hollywierd, FL
    2,779
    wire them in series and set esc to brushed mode. should work fine.
    Run it, break it, fix it, love it :]=~
    Mar 2006
    MI
    4,478
    Quote Originally Posted by DickyT
    Wouldn't you want to wire the motors in Parallel so each motor sees full voltage.
    Jan 2007
    Hollywierd, FL
    2,779
    Quote Originally Posted by cuda_tmaxx
    yes, I mistyped that.
    Jun 2007
    Springfield, VA
    1,580
    Hmm.... maybe there was a reason my Novak LVC was backordered.
    Now, if I place an order at Tower, what will I need for it? Bullet connectors? Wire? Obviously some kind of connectors for the batteries.
    Jan 2006
    549
    Wow I didnt know you could do that. That would make using lipos allot easier and still use the titans for a while..
    When you buy the mmm you need the programmer seperate rite? I donr think its like the mm as it doesnt have a built in usp port.. Anyone got a link to the special programmer cord or does it come with it?
    Brushless makes everything taste better
    Mar 2007
    near New Orleans
    5,899
    Quote Originally Posted by Dragonfueled
    It will come with it:
    "The Mamba Monster ESC includes Castle Link™ USB Programming Kit– drivers can use their Castle Link and a Windows PC to tune and tweak additonal settings, such as:
    Throttle response curve
    Brake response curve
    Saved profile setup files
    Punch control
    Separate brake strength
    Separate reverse power "
    E-Maxx Neu1515 1y/MGM 5s
    Feb 2008
    Chicago, Da Burbs
    2,373
    Jun 2007
    Springfield, VA
    1,580
    jay, does this wiring account for the fact that one motor spins in reverse of the other?
    The 6.5mm bullets should suffice, no? 12ga wire should also be plenty for the brushed motors, right?
    Sep 2006
    569
    Quote Originally Posted by mbeatle
    All you need to do is flop the polarty on one of the Titans to reverse the rotation.
    Jul 2007
    Tulsa, OK
    337
    Quote Originally Posted by skellyo
    Or if timing on the motor is an issue, you can either adjust it or - if you want to just play it safe, spring 12 bucks on a new Titan (non-reversed).
    3906 E-Maxx, 3905 E-Maxx, SC10, RC10, TQ10
    Jun 2007
    Springfield, VA
    1,580
    Alrighty then, what connectors (and how many) do I need to hook this stuff up? I've read different things about how things will be on the first run. If I need to order 2 packages of 6.5mm bullets then I'll do that.
    Oct 2003
    Show Low Arizona
    136
    huh?
    I dont see the point in this? Why would you want to spend 175 on the MMM to just run the stock titans that the stock evx-2 runs just fine,A 7xl or 8xl arent expensive, Why not just pick up one of them until you can afford a Neu. I dont think you will beable to put more volatage to the titans.
    Jun 2007
    Springfield, VA
    1,580
    I'm not trying to get anything more out of the Titans. I plan on brushless anyway, and rather than spend $25 on an LVC (or $50 on two) I can get the MMM which I planned on buying anyway which has a built in LVC. I also don't have to worry about the EVX2 smoking my motors or batteries (rumors abound). When the Titans finally give up the ghost I can pony up the $100+ for a Medusa, Mega, etc. I don't think the truck will be boring to drive on brushed power, but I have bigger plans down the road. No sense in sinking money into LVCs that I'll never use when I get what I REALLY want.
    Jun 2007
    Springfield, VA
    1,580
    Alright, I'm piecing together an order list. Can anyone confirm how many 6.5mm bullet connectors you need for the MMM? I plan to order tonight. There are 5 plugs in the prerelease pictures, but I've read that some will have wires with bullets already.
    In wiring up the motors:
    ESC + to Motor 1 +
    Motor 1 + to Motor 2 -
    ESC - to Motor 1 -
    Motor 1 - to Motor 2 +
    I already have a 14awg Deans series adapter for the batteries.
    Oct 2006
    Palm Harbor, FL
    2,770
    LOL That's no rumor.... Pure fact, been there, done that... LOL
    Support USA products whenever possible !!
    Oct 2003
    Show Low Arizona
    136
    Oh I see, So its just a temp thing and to try to save dough on something you dont need. I get it now thanks for clarifying
    Jun 2007
    Springfield, VA
    1,580
    Basically, yeah. I could eat the elephant all in one sitting, but I think I'll appreciate brushless more when I don't have it to begin with. I had brushless from day one with my Stampede. It didn't leave me much time to really learn the truck because it was so fast.
