Does anyone know if....
Will these fit on my 4 tec 3.3? HPI NItro RS4 Series Aluminum Shocks? Do you suggest I use these or use the Big Bore? Either way, just wondering if the HPI's would fit properly...
Also, are Vantage Pipes really that great? I don't want to assume for $80 + $$$$.
I would guess they would mount differently
ive heard of tc3 shock but not rs4 on a 4 tec, what are the demesions. length, width storke. the big bore's are already a tight fit so if they are wider that would be an issue. i have the big bore shocks and run tc3 springs on my tec and love that combo. tc3 springs are rated in lbs and not just color coded. the springs run 5$ for a set of 2
Thanks for the advice. What set-up do you run? As far as color/lbs for front and rear. I plan on running this mostly on smooth concrete or parking lots.
- You may not post replies
- You may not edit your posts
Forum Rules
