I am still on my first gallon of 20 percent, the only fuel that I ever used...
After breaking the engine in, running the vehicle for a few days...
The engine will not start.
Symptoms started with stalling, at high speed, then stalling when starting. Now it won't start. With throttle in one hand and ez start in the other, it will start, and I can give it a little gas above idle while holding, the vehicle will burn fuel as long as I am holding the ez start button. As long as I hold the ez start button the engine is running. When I relase the ez start button the vehicle stops immediately. I checked the fuel line, it is good to go, I repalced glow plug and blue glow plug wire. I verified the yellow wire is attached. I have not replaced any internal engine parts. I am tuned to very close to factory settings, with in a quarter turn of factory of HS and dead flush to ls factory recommended setting...
I don't have a clue. Unless I did run too lean for too long as fuel has been run out of the engine on more than 1 occasion, closer to 4 or 5 times.
I am new to these very fun, very fast, very cool little cars, I wanted to touch base on this forum before I just went out and got new internal parts...
Thoughts and suggestions are welcomed...
thanks
(not really, but WD-40 does more good than harm).
