Results 1 to 23 of 23
    Jul 2007
    marrietta GA
    2,579
    Gotta Jato!!!!!!!!!!!!!
    Well for christmas i got a jato! Its used so can i use it know or do i have to do stuff to it. Its my first nitro.
    You can only have 2
    Cheap-Performance-Reliability
    Mar 2007
    western NY region
    2,097
    cool...i'd just give it a once over and check everything out on it, ie: make sure all the screws are tight, and check and see if any parts on it might be damaged and replace them as needed...and you should be good to go...if you want some info on nitro tuning etc. let me know...good luck with your jato!!!
    ***some advice: don't go all crazy with the WOT passes until you get used to the speed of the jato, and be sure to have plenty of room to stop!...it accelerates way faster than it stops thats for sure...
    edit:
    here is where you can find the manual cuda_tmaxx mentioned below...
    JATO 3.3 troubleshooting and resources (<-- click!)...
    "Growing OLD is mandatory, Growing UP is optional"
    Mar 2006
    MI
    4,478
    The first thing you should do is read the manual. If it did not come with one, traxxas has them all posted.
    I tried being reasonable, I didn't like it.
    Sep 2006
    Yo Mamas House
    438
    +100 with what red and cuda said... get to know it before you take it out.. its a speedy lil truck
    E-Revo in progress =)
    Mini E Revo =)
    Jul 2007
    marrietta GA
    2,579
    I cant start it. When i put the EZ start in it and pull the throttle it doesnt go. How do i prime it.
    You can only have 2
    May 2007
    Sandy, Utah you can find me at the construction bash site a lot
    1,773
    Well read the manuel and all first and familirize yourself with it and you press the red buton read the manuel and it tells you all that stuff.
    Agree with slowenufs sig wheres the new 4 tec?
    Jul 2007
    marrietta GA
    2,579
    When i prime the engine i just put my finger over the exhuast right?
    You can only have 2
    Apr 2007
    California in the YAY AREA!
    4,343
    Yea put your finger over the pipe and try to start it for like 5 seconds I think or till the gas gets all the way to the carb. Then make shure to break it in.
    No more money for rc trucks I got 1:1 truck
    Jul 2007
    marrietta GA
    2,579
    Its used so im assuming it broken in. He sais he put 10 tanks through
    You can only have 2
    Apr 2007
    4,343
    Oh, you got it used. Whell you can't be too safe, just take a easy for afew tanks.
    Jul 2007
    marrietta GA
    2,579
    When ever i take the EZ start out it shuts off. Why wont it start.
    You can only have 2
    Apr 2007
    4,343
    Glow plug might be bad. They are like $5. But I don't think any hobby shops are open today so you are going to have to wate. It also might be it isn't warm, blow dry the head for like 2 minutes and try and see if it stays alive.
    Jul 2007
    marrietta GA
    2,579
    I got it started. I guess it was a christmas miricale. I didnt think it could go that fast.
    Its just when i accerlerate it starts to slow down then it takes off. I think it just needs to be tuned better.
    Merry Christmas!!!!!!!!!!!!!!!!!!!!!!!!
    You can only have 2
    Apr 2007
    4,343
    When it does that I think the lsn is not tuned but I am not shure. You can check it. When it is warmed up pinch the fuel line by the carb and it should take 3 seconds to turn off. If it takes more you need to lean it and if it takes less you need to ritchen it. I think that is how you do it.
    Jul 2007
    marrietta GA
    2,579
    The HSN is the oe that sticks out and is goldish/yellowish right.
    You can only have 2
    Mar 2003
    Wherever the road takes me.
    36,174
    The high speed needle looks like this:
    http://www.traxxas.com/support/pub/i...spd_needle.jpg
    Oct 2007
    678
    +1 on that cooleocool..let us know how its goin
    Mar 2007
    western NY region
    2,097
    your best bet would be to get a few extra glow plugs when you can, just incase you blow one...and maybe you might want to reset it to factory settings and start tuning from there, so you can begin learning the tuning process from the start...nitro engine tuning is kind of like an art, tricky at first but once you start getting the hang of it, it gets allot easier...just be sure to read the following carefully so you get a better understanding of the nitro tuning process, and be sure to read the manual for your jato as well...well on to factory settings and some tuning info...
    a general "rule of thumb" when tuning and you lean out your HSN, you have to richen your LSN...this is because when you lean out the HSN it restricts the flow of fuel to the LSN, hence you have to richen the LSN to maintain a proper air/fuel mixture & reliable idle...and same applies when when you richen your HSN, but (opposite direction) you lean out the LSN to maintain the proper air/fuel mixture...so w/that said always remember reset carb to factory settings (<-- Click!) when your tune is way off and start re-tuning from there...in the following links there are "tuning guides" for nitro engines...they have really good info in them to aid you in the tuning process...and as for tuning yes the 2.5 & 2.5R & 3.3 are all tuned the same way...incase anyone was wondering...and always begin tuning after you have run through 1/2 of a tank of fuel to ensure the engine is at normal operating temp, and to prevent the dreaded 1/2 tank lean bogging...use a temp gauge for double checking your tune (if one is available, i find the Duratrax FlashPiont (<-- click!) works very well)...and DO NOT tune for a specific temp...ONLY use the temp gauge to make sure you stay UNDER 270 degrees...(Click! -->) Tuning Guide #1, Tuning Guide #2 & Tuning Guide #3 (<-- Click!)...and finally here is another usefull tip, you can "read" your glow plugs to verify if your tune is good or not...and as for "reading glow plugs"...you should do it after you have ran 2-4 tanks on a fresh plug...then take it out and "read" it...here is some more info on reading glow plugs (<-- click!) with illustrations...and it would be a good idea to bookmark these links for future reference incase you need them, they have allot of great info in them...the last one even goes through finding air leaks and getting that last percentage of the "perfect" tune on the second page of it...good luck!!!...
    Dec 2004
    289
    Make sure you check your motor mount hexes after each run. Save you alot of spurs. That is one of the first lessons I learned. Run it a little rich if you do not plan on racing it.
    Jul 2007
    marrietta GA
    2,579
    Thanks for all the info. It stopped raining here so in about an hour my friend and i will go drag race. he has a O.S T-Maxx and a HPI viper
    His truck is the king of hour nebior hood. My friends and i race a championship to see whose the king. He was the only one who had a nitro car so he could easily beat my xl5 rustler, my brothers xl5 pede, my friends Team Associated buggy and my two other friends team losi buggies.
    The point of king of the neighbor hood is for the non-kings to buy you a part for your car with thier money together.
    It may sound stupid but if 5 people give you 5 dollars it can help you.
    You can only have 2
    Jan 2006
    Ford Country
    948
    Quote Originally Posted by rustler 007
    His truck is the king of hour nebior hood. .
    scissors to his fuel line will help you
    but that sounds like a good time! good luck next time you run for king
    Smooth is Fast. Slow is Smooth. Therefore, Slow MUST equal Fast.
    Apr 2007
    4,343
    lol yea but do you think he would find out if he had two fuel lines and they both don't go the tank or the carb? Here is what you do if he has a fuel filter, simpally pull the line off the filter and it looks like it fell off on its own. Jk, how would you start it with a non-complete fuel line?
    Oct 2007
    678
    lol yeah then it wont start but im pretty sure a jato can beat a os maxx..looks like your neighbor hood has a new king..lol
