im thinking about changing my rusty to a pede but i need to kno what to get so could you guys help me out here and i only have about 200 bucks so not to expensive and with that wat battery and charger should i get
Those who throw dirt are bound to lose ground.
you can get the parts on ebay for a good deal if you look around.
Want a TJ wrangler near Louisville, KY under $4000
for two hundred bucks you should be able to buy a new one
if ya can't roam wit the pack go play wit the pups
i know but i still want part of the fun and looks of a rustyOriginally Posted by solardragon
^^^or on ebay a used one
you could start by putting masher 2000's on it then if you like it taller like that just do the full conversion
thanks guys for the help
2 xl1 rustys 1 bandit no hopups
dont forget to change the pinion after u upped ure wheels... idk, but i found out that the rusty just isnt suited to tall grass like the pede would, and i had to gear my pinion from a 16 tooth to a 13 tooth and the motor was still sorta hot after i was done! good luck with the conversion tho, ill have to take a look, i love readin stuff about these :P lol
2.5 Tmaxx
Soon to be MM E Rusty
