+ Reply to Thread
Thread: Wont Start
    Mar 2001
    Barnesville,OH, U.S.A
    66
    Unhappy Wont Start
    My fuel in my line will not move to the carburator. I put a new gas tank on it and all new fuel lines and i ckecked my fuel filter. I dont no why it wont start. Please help. I called 1-888-traxxas and they said that i should clean my high speed needle. But how do you clean it and what do you use to clen and could that be my problem. Please help me.
    RC Turnbuckle Jr. fanman's Avatar
    Apr 2001
    Auburn, Michigan
    3,503
    take the presure line off the pipe and the line off the carb, clean the outside of the presure line with a papertowel, then blow into it (inhale before you put your lips on to the line. if there is fuel comming out the other end then the line/tank/fuel filter are fine. next check the high speed needle, take it out and under a bright light look into it (both ends), it would also be a good idea to flush it out with some clean fuel.
    Everyday I beat my own previous record for number of consecutive days I've stayed alive.
    http://community.webshots.com/user/fanman_2000
    Oct 2001
    17
    i have the same problem . i would pump and pump and ump the primer but fuel wouldn't go into the carb.
    Oct 2001
    aurora,il
    20
    Me too i had the same problem.
    just my 2 cents
    Registered User
    Oct 2001
    159
    Have u got it started yet?
    Jan 2001
    Fresno, CA
    2,008
    are you using the primer pump if you are not your motor maybe so warn that it wont draw the fule in any more
    3.3 t-maxx, O.S. .18TM t-maxx, HV brushless e-maxx
    Oct 2001
    sydney australia
    73
    press the ez start and put your finger at the exhaust
    traxxas ready to win
    (with hopups)
