I JUST PUT ON A SPUR GEAR AND I TIGHTENED IT AND WHEN I SPIN THE TIRES IT LOOKS LIKE IT'S LOOSE AND WOBBLING AND THE BAR IS BENT. BUT IT'S NOT![]()
This is normal as long as its not wobbleing alot. If it is you may have your friction-clutch setup wrong.
Check out the instructions on the traxxas.com site, it may have what you need to answer you questions.
JATO | REVO | Nitro Stampede
IF ANYONE KNOWS HOW TO FIX IT CAN YOU TELL ME STEP BY STEP BECAUSE I'M NOT FEELIN SPENDIN LIKE 50 BUCKS TO FIX IT AT MY LOCAL HOBBY SHOP
EVERYTIME IT SPINS IT WOBBLES
stampede psyco it is normal for the spur gear to wobble a little but . if you can see nothing wrong with it just drive it and see how it go's![]()
DISTURBED
yeh drive it and see how it goes or take it to your lhs
electric rustler souped up and about to d a project on my bandit
if the spur gear wobles when it spins at low rpm's then it will probly straighten out at higher rpm. as long as the mesh is fine i think you should be ok.
Everyday I beat my own previous record for number of consecutive days I've stayed alive.
http://community.webshots.com/user/fanman_2000
just run it at WOT for a few seconds that should help
Let the sleeping dog lie.... shouldent he tell the truth??
ok thanx all . i have another problem my car just won't start everthing is perfect. i just bought a new glow plug today and it still won't start the hobbico battery is full so i now it's not that and it's not flooded. the car won't even try to start.
Hey check your fuel mixtures.
High speed
Low speed
idle needle
just my 2 cents
check if the 2 gears are meshing well!
NITRORUSTLER=800$
OS.15CVX=300$
blowing away the compition =priceless
i just checked the 2 gears aren't meshing well i tried to put the engine closer but it woun't go i'm starting to get really ****ed can someone help
