well I had a 8 turn motor in my pede and not geared right. after I got theGTS I found out that I have to use my 19 turn. But heres my question will a 8t motor not geared right be faster then a 19 turn geared right??
No one can really say for sure... I'd try it though! Do you have a 19-turn modified motor or a 19-turn spec motor? You'll have much more torque, that's for sure... At least you should!
not really sure b/c I have not ran this motor in awile. But I know that it's a 19 double turn motor
What kind of motor is it?
the motor is Quartz
Quartz as in old speed gem motor? Like Speed Gems II?
I saw in another thread that you said somthing about the 17t motor from Team Orion. is that much faster then the speed gems??
It should be a bit faster since it is a lower turn motor. I see around 3ish mph between my 19 and 17-turn Orions...
I'm not so sure on this so i'll ask. What would I gear a 14t to get the most speed and not melt wires??
I'd get a 12-tooth pinion with the stock spur gear.
It's not that you'll melt the wires... You'll be over geared which is bad for the electronics.
