Results 1 to 15 of 15
    Minnesota
    296
    locked up wheels?
    hi, ive got a jato 3.3 and the rear tires are locked up or something like that. i can spin one and the other will spin the opposite way but they wont spin the same way. the engine still runs but wont move when i give it gas. whats the problem?
    Matthew 19:26
    Jul 2011
    S. Jersey
    713
    Check ur clutch.
    Minnesota
    296
    what would be wrong? does something need to be adjusted or replaced?
    Matthew 19:26
    Jul 2011
    S. Jersey
    713
    Possibly the clutch spring.
    Minnesota
    296
    is that an easy fix?
    Matthew 19:26
    Jul 2011
    S. Jersey
    713
    If is the clutch spring then its a pretty easy fix.
    Minnesota
    296
    how can you tell whats all broken? would this be a cheap fix?
    Matthew 19:26
    Jul 2011
    S. Jersey
    713
    Take off your spur gear then remove the clutch bell. Make sure the spring around your clutch is intact. If its broke you need to replace it. The spring is a cheap fix it that's your problem.
    Tanker 822
    9,631
    Spin one tire and the other spins the opposite way is the normal operation of a differential. When the engine runs and you give it throttle and it does not move, then the slipper clutch is too loose. If you cannot push the vehicle while it is on the ground, then it is possible the clutch shoes/spring broke. Best indicators that it is indeed broken is that the truck wants to move when you start it and will only start with the tires off the ground and even then the tires spin while starting. Or the engine stalls when you come to a stop.
    Minnesota
    296
    i found out the clutch needs to be replaced. thanks for the help.
    Matthew 19:26
    Jul 2011
    S. Jersey
    713
    No problem.
    Fort Dix NJ
    38
    the stock clutch is less than desirable, I put a BUKU in mine and its 1000x better
    Burbank, IL
    95
    To bump and add to the thread, if I'm reading this right, if I can push my car on the ground (with the engine off) and the tires don't lock up, this is normal operation correct? Thanks
    Burbank, IL
    95
    Bump anybody?
    Jul 2011
    S. Jersey
    713
    Quote Originally Posted by 19frank90 View Post
    Yes that is normal
