Originally Posted by
maaloomi
I just came back from a little session (2 hours) i askes a few guys to help me out, what we did was closed the LSN alot (bout 2 full turns clockwise) and opened the HSN abit 1/2 turn , we fideled around with it for a bit and then we set the IDLE screw so it will run a bit higher...
The car whent crazy, the throttle is alot more "punchy" and it sounds alot better...
Problem now is that it heats up alot... Can this be mostley becouse of the LSN, or should i open the HSN a bit??
Some1 down there told me that the LSN dosn't effect the temp as much as the HSN and i should open it a bit till it dosn't heat up...
Is this good advise???
Or should i try something else???
O, the car dosn't go off anymore, it runs on a bit higher revs (idle)
