+ Reply to Thread
Thread: Help PLease!
    Apr 2006
    138
    Help PLease!
    I just got the RPM arms I got the front in fine but on the rear. How do you get the rear battery box commpletey off to get the pins out for the rear arsm. I took out the 2 screws inside. There is one more but it is facing the oppiste directions. I dont know what else to look for please help!
    Apr 2006
    Millville, MA
    35
    Remove the 2 screws holding the rear diff case to the chassis. Carefully pull back towaards you. You should look to clean the whole rear area prior to doing this as the rear end gears will be exposed. I may suggest looking at the owners manual as they detail how to do this as well.
    Good luck,
    Jared
    If you're living on the edge, your taking up to much space!
    Check out my friend Joe at www.creativehobbies.net
    Sep 2003
    Mesquite, TX
    1,706
    also... go print off the Jato exploded views from the Traxxas Jato product page... they will help you see how everything goes together.
    9R
    May 2005
    Rewey Wisconsin
    1,011
    Go here....
    http://www.traxxas.com/support/index...cat=110&id=495
    There is a complete walk through on how to get the rear box off.
    Redlined Man
    Git -R- Done, RC Style; Big Air And High Speeds
    Apr 2006
    138
    Thanks I got it now. But read my other post now more troubles!
