+ Reply to Thread
    Jan 2005
    Nuclear Power Plant drainage ditch
    1,901
    Powerpole plug question...
    Bought some Powepoles/Sermos/Anderson plugs. My question is whats the best way to either crimp or solder them? With crimping it seems to make the part crimped too wide to slid into the plastic housing. With soldering, do I tin the wire and metal end, then insert wire and heat both of them up? Not a lot of access there. Thanks.
    All those who believe psychokinesis raise my hand
    Sep 2004
    puyallup wa
    2,976
    i think they sell one at radioshack.i use this one.http://www.powerwerx.com/product.asp...025&CtgID=1682
    "bah weep granah weep nini bong"
    Jan 2005
    1,901
    I see. Need a special tool for crimping.
    What's best for RC use, 15, 30, 45, or 70 amp Powerpoles?
    Sep 2004
    puyallup wa
    2,976
    i got the 30amp ones.i mean you can use needle nose pliers but it is much easeir to use the tool.
    Sep 2004
    puyallup wa
    2,976
    this tells you alittle more on crimping.http://www.flyrc.com/articles/using_powerpole_1.shtml
    Jun 2003
    Bowling Green, Ohio
    2,100
    Needle nose pliers won't give you a good crimp.
    I've tried both the GS-88 crimpers and the Radio Shack Crimpers. The Radio Shack give a better crimp.
    Rustler with Stampede Body Mounts, Masher 2000's, Futaba 3PDF Radio, Tekin Rebel ESC, Magnetic Mayhem 23/87, SG2 Amber 14/87, misc 8-cell packs, RPM all around, Lunsford Turnbuckles.
    Nov 2002
    Calais, Vermont
    700
    The best way that I have found to solder them is to hold the wire upright with the connector portion sitting on the end. Then heat up the connector from the backside with your iron and drip solder down through the top of the connector until it is comming out of the bottom.
    This way ensures a good connection, as long as you get the plug and wire hot enough.
    It sure seems like sense is no longer common.
