+ Reply to Thread
    Nov 2005
    41
    has any one put a thiner washer under there trx 2.5 head
    i just picked up a pack of cooling head gasket because i am going to put the power tune head on from traxxas but the pack came with 0.15 0.26 and 0.35mm gaskets has any one used a thiner /thicker one is it safe and dose it help in power
    Feb 2005
    vacaville Ca.
    912
    i think there different so u can use them with different % nitro fuel so im guessing the .15 would be for 10% , the .26 would be for 20% and the .35 would be for 30%--33%, but i have been wrong
    Novarossi Powered Truggy, FLM VXL Rustler.
    Banned by Warnings
    Apr 2005
    2,035
    those modify the compression ratio. the thinner the gasket, the more compression.
    more compression produces more power, but there are drawbacks such as more stress on the con rod which eventually results in reduced engine life.
    i think stock is .26 use stock, but if you require more power, you can try to use .15.
    Banned by Warnings
    Jul 2005
    NEW JERSEY
    365
    use the stock shim unless you know what you are doing you may get an airleak, use an really thin flat head screw driver or thin razor blade to flip it up
