+ Reply to Thread
Results 1 to 11 of 11
    traxxasmike
    Guest
    HELP! Novak SS5800 problem
    Well the other day I was bashing around in a parking lot racing an e-maxx. Ran great all day. Then i was full speed and ended up hitting a curb before I could slow down enough. It didnt take that hard of a hit but I just busted a steering block and had it running again the next day. Well i took it out again and after about 2 minutes of running back and forth on the street, it started making a strange noise after take off and could not get up to speed! I opened up the motor and sprayed some motor cleaner in there, everything seemed normal so i put it back together. this didnt fix the problem. Im hoping this problem is not in the electronics! Im wondering if I can send it to novak and they can replace it. It was purchased christmas time. Any one have a possible solution or has had this problem?
    -traxxasmike
    RC Champion jtcfanof3's Avatar
    Mar 2002
    Sullivan ILLINOIS
    2,922
    Sounds like a cogging issuie,which meens you need too check your sensor wire plug on the ESC,amke sure its plugged in all the way.
    You may have damaged a sensor wire it sounds like too me,hopefully the plug has just come out a little bit and can just be plugged back in.
    "Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same."
    Ronald Reagan
    traxxasmike
    Guest
    Well I disconnected that and sprayed cleaner on there. Made sure all the little metal tabs were there and ok. Just took it out for a run and it was fine at first but then it came back. Its like a low pitch loud sound. and then it makes high pitch chirps. and no its not glitching.
    Mar 2002
    Sullivan ILLINOIS
    2,922
    No that sound is "cogging" and it sounds like you may have damaged a sensor in the motor,or a a mosfet in the ESC.
    Sounds like a trip too NOVAK is in order buddy .
    Ronald Reagan
    traxxasmike
    Guest
    Do you think they would replace it for free?
    RC Turnbuckle Jr. razer's Avatar
    Oct 2002
    Streetsboro, Ohio
    15,087
    You'll have to contact Novak to find out the answer to that one.
    There is no chicken knife. Eat steak.
    traxxasmike
    Guest
    Well thank you very much for the help I hope Im running again soon.
    May 2004
    TN
    676
    Re: HELP! Novak SS5800 problem
    -traxxasmike
    You're running your emaxx with a 5800?
    May 2005
    Cincinnati, OH
    100
    I think he meant he's racing against an emaxx.
    If he were having problems with an emaxx, I'd hope he'd post the problem in that forum, not in the stampede forum.
    <┐rim⌡ack
    Jul 2004
    Reading, Massachusetts
    2,083
    Agh!! Don't spray motor cleaner inside the SS5800 motor! Novak doesn't recommend it. Hopefully you got lucky and didn't damage anything else.
    Jun 2003
    Bowling Green, Ohio
    2,100
    Did you re-oil that front bearing after spraying the motor? You might have a dry bearing.
    Rustler with Stampede Body Mounts, Masher 2000's, Futaba 3PDF Radio, Tekin Rebel ESC, Magnetic Mayhem 23/87, SG2 Amber 14/87, misc 8-cell packs, RPM all around, Lunsford Turnbuckles.
