+ Reply to Thread
    Mar 2005
    Front Royal, VA
    96
    Rear differential question
    Being new to E-Maxxes, I had a question I hope someone can help me with. Last night after running, I brought it home and was cleaning when I noticed that all around the seam where the differential goes I had dust stuck to an oily residue. Is it normal for the diff to seep here, or do I need to take it apart and tighen it up or reseal it? Also, I think I remember reading, but correct me if I'm wrong, it's nomral to have some oily residue on the bottoms of the shocks? I have a little bit in the rear, almost none in the front. Thanks for any suggestions.
    Jeff
    EMBE, RPM skids
    Electric 4-tec, all stock
    Mar 2005
    Lexington, NC
    41
    Completely normal. The diff housing is not sealed. So it will leak a little. As far as the shocks, with use they too will leak. The dust collection on the shaft only serves to wear the seals, making them leak.
    Do you know who is watching....
    Mar 2005
    Front Royal, VA
    96
    Thanks for the tip...does the diff require a normal refilling with lube, or is the leak small enough that it's not wrth worrying about?
    Jeff
    EMBE, RPM skids
    Mar 2005
    Lexington, NC
    41
    The diff will need to have periodic maintance done on it. That inolves removal, cleaning, refilling the diff cup with diff oil, and adding diff grease to the ring and pinion gears.
