i just had my rusty out for the first time in a awal then after driving a few tanks it started to whistle any ideas wats wrong.![]()
R.I.P. To the greatest driver to ever live Dale Earnhardt. 1951-2001
anybody i know im not th first i think its from the transmission but im not sure
Do you mean revving up? Are you still running as fast as you were? Check your spur gear, and slipper clutch
im still runing fast i guess it sould be my slipper
Is it whistling after your do high speed runs, like when you are done going WOT and you led off the throttle without braking? Your slipper should be set at, tightened all the way down until force, then backed away 1/4 turn. Dont go more than 1/2 turn back. This is for the 2.5 Engine.
ok ill try that it starts whisteling when i lay on the throttle
That is normal then. That is your motor decreasing its rpm's i believe.
