need help adjusting camber...
hey i just got my stampede from someone off this site. everything works great but it just seems like the wheels are going like this... / \ does anyone know how to fix this????? your help would be awsome. thanks,
chris
thats ok for the wheels to be like that. that means the camber is set at a negative setting and you want that. also if you have the stock camber links then you can't ajust them. You would need to buy turnbuckles and install them where the camber links are now located.
Actually with the "stock" set up, if the Turn buckles from the Servo Saver to the Carriers are "ajusted" it can cause the wheel geometry to not line up right and it does look like it's a Camber issue if you aren't looking closely (I just encountered this when I had to replace a Rod end due to a Nasty crash with the Railing Pole >.<)
the stock camber likes are not ajustable because camber has nothing to do with the turnbuckles. Thats called toe-in and that is compleatly different from camber. Also you want the camber and the toe-in to be like / \ that anyway. So don't change it because it's good that way.
- You may not post replies
- You may not edit your posts
Forum Rules
