Results 1 to 4 of 4
    joeracer
    Guest
    Cool slipper clutch adjustment
    I've recently purchased a Nitro Rustler. I'm having a little trouble with adjusting the slipper clutch (I melted my last spur gear). Can anyone inform me of the proper way to adjust a slipper clutch? It's a 70 tooth.
    Apr 2001
    york pa 17402
    10
    Cool
    Tighting the nut all the way then back off 1/2 turn for dirt or 1/4 for pavement good luck
    DRIVE IT FAST,& HAVE A BLAST!!
    Banned
    Feb 2001
    327
    Post
    put it as tight as it gets then aply the brake and push it, if the slipper clutch dosn't let go then lossin it.
    joeracer
    Guest
    Question
    okay, i tried it. i had to do a lot of things. first, i realized that my throttle servo was hooked up backwards. that might explain why i burnt the brake up during first use. i replaced the brake (still with the servo backwards) and the next thing that happened whas the spur gear meltdown. the cogs were gone on the gear, and the innerbushing was melted to the inner radius of the sprocket. reconnected the servo correctly, and replaced the original spur gear (70 tooth) with a new one (72 tooth). loosened the motor mounts and replaced the spur. car is still sluggish on take off. i think i may have everything else adjusted correctly. even did the paper trick with th e gear mesh...wow...
